Is This A Good Aftermarket Throttle Body ??? Opinions Please
Old 12-01-2007, 03:14 PM
95transamlt1's Avatar
Default Is This A Good Aftermarket Throttle Body ??? Opinions Please
I have a stock ported throttle body on my 98 ls1 with heads and cam full bolt ons with ls6 intake . will this throttle body work good how is the quality? Does anyone have one of these or know about this company ? thanks guys
http://cgi.ebay.com/ebaymotors/Profe...spagenameZWDVW
Old 12-01-2007, 03:18 PM
Soul TKR's Avatar
what company?
can't tell the quality without pics...
Old 12-01-2007, 05:10 PM
10 Second Fun Car
jlrz28's Avatar
Something wrong with the one you have?
Old 12-01-2007, 08:43 PM
no i have a stock ported one but i have an ls6 intake and i feel like i need more air coming in since i have heads and cam . thanks
Old 12-01-2007, 08:48 PM
Tainted's Avatar
your stock P&P TB is fine, the ls6 is holding you back more than the TB or hell even the lid now that we have an 85mm one available
Old 12-01-2007, 08:50 PM
which one is the new lid cause i have an slp lid and will the new lid give me more power. thanks
Old 12-01-2007, 08:52 PM
Tainted's Avatar
the FTP 85mm lid. yes it will give you more power. and no you dont need to mess with your stock MAF, its good to 500hp+
Old 12-01-2007, 08:54 PM
Sluggish's Avatar
if you notice the walls of the Professinal Products TB are just as thick as a stocker.If you did purchase this TB i would have it ported and polished. I had and issue with the idle air control plunger on this TB. The hole was a little big and the oem would get stuck. I had to go to Napa and buy another (around $100 bucks). This one had a larger plunger with a rubber boot that worked.
Old 12-01-2007, 09:04 PM
i think ima order that new fast toys lid i read good things on that lid. thanks
Old 12-01-2007, 09:12 PM
10 Second Fun Car
jlrz28's Avatar
Just like everyone else said keep your ported and polished tb unless you think it could be better and make sure you have it ground where it opens up 100%. Dont mess with the MAF, people mess with these and then cause tuning problems. Just take the screen out and be done with it. The lid shouldnt matter much you should be fine.
Old 12-01-2007, 10:43 PM
Restricted User
Smokin87TA's Avatar
I have personally had several of those 80 and 85mm units come to me to get ported and they are what they are, very cheap which means all the parts are very cheap as well. I was going to use one on my car but decided not to since its pointless to go with anything bigger than stock while still using a ls6 intake. If you get a tb you still have to use a reducer to get into the 78mm ls6 intake. Now if you had a 90mm intake then the 85mm tb would flow more air. And yea they definitely need alot of work to flow great, basically like a stocker thats unported. Tim
