need a pic of pacesetter LT's and pacesetter ORY installed! hey guys, can any body show me a pic of pacesetter LT's installed on the car with there pacesetter ORY? i am going to put some cats on the pacesetter Y pipe so i need to know how close the y pipe is to the floor board! and which part of it has the most clearance for a cat! thanks alot guys the catted y is way to expensive |
i thought in california if you moved them from the stock location you were already violating smog laws. |
the passenger side is easy (plenty of room) but the drivers side would be very tough. the problem is, because the pipes are crushed to make room, to take advantage of that, u want it close to the floor. to fit a cat on there, u would be moving it away from the floor...sacrificing ground clearance, and defeating the purpose of the crushed pipe. plus, the only place to fit the cat would be right before the y merge, and there are hard lines right there that make it a very tight fit. and i dunno about u, but i dont want my cat touching any of the hard lines (hence, why i took my tsp catted y pipe off) |
Originally Posted by sreve
(Post 8268637)
i know a few people who are willing to pass me and smog tests, usally the machanics are always to lazy to check under the car anyways, so im jus gonna try to pass the sniffer test but thanks alot guys well i was thinking of dropping my car pretty soon. well i guess im jus gonna have to do that after the header install! to see how much clearance im going to be working with! |
(Post 8268637)
looks lik there is some room to work with but then again this is a lt1 formula so i gotta mak sure but i appriciate all your help! happy holidays to everyone |
sniffer test? WTF is that for a '99? obd2 here is plug in, no check eng light readiness tests, can have 2 not ready '00 and earlier 1 '01 up not ready |
If no body gets you a pick before I do I am putting mine on the news years eve. I will get you pics then if nobody does before. Im putting pace setter lt and ory on. |
(Post 8278922)
Originally Posted by penningta
(Post 8279181)
Originally Posted by ae13291
(Post 8279945)
the sniffer test in california, is they put a probe in ur exhaust pipe and, thats how all the emissons are tested and also they look at the catylst sticker annd check to see all nessacery things are there, and they look under the car as well! they do this test for all OBD cars the sniffer a few years back. i could not be happier. its scary though,those effing nazis at carb seem to be able to run there BS down everyones throat in time. |
(Post 8268637)
The pacesetter headers and y-pipe tuck VERY close under the car. I actually had to do a little BFH mod on the driver's side floor board to get the non-catted y to fit. |
| All times are GMT -5. The time now is 09:09 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
