LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Head Delima: Head Guru's Please Read! (https://ls1tech.com/forums/generation-iii-external-engine/833312-head-delima-head-gurus-please-read.html)
beanx Dec 20, 2007 10:04 PM
I have found 3 sets of heads they are all pretty good deals i think but im not sure which set is the best. What are your guy's opinions. My mods are in my signature and i plan on doing a small mild cam later on down the road but not anything to soon. I would like to buy the set of heads that im going to see the biggest performance increase from even if i would have to mill them or do some other kinda machine work to them. But what are your guys' thoughs? Thanks in advance!!!!!!
*EDIT*
And if it helps here is a link to stock LS1 head flow numbers and some other information here, http://www.smokemup.com/tech/ls1.php. Also here is a link to Patriot Stage 3 Heads, Patriot Stage 2 Heads. I Guess you could do some comparing between them and stuff with the first set of heads. Thanks alot guys i apriciate it!
Set #1
5.3 heads that are stage 2.5 ported by Vinci racing. intake valves is 2.02 exhause valves are 1.60
http://i47.photobucket.com/albums/f1...S/DSC_0011.jpg
http://i47.photobucket.com/albums/f1...S/DSC_0010.jpg
$930.00 shipped
Set #2
TEA Stage 1 heads 62cc with 2.02 and 1.55 valves. No flow chart guess the guy put down 430rwhp though.
$500.00 shipped
Set #3
2.00/1.55 inch valves PRC Stage 1 LS6 CNC Ported Heads beehive ls6 springs milled to 58cc 243 heads.No flowchart but guy claims 400ishrwhp with these heads.
$850.00 shipped
beanx Dec 21, 2007 04:02 AM
Ttt!!
bryan04h Dec 21, 2007 07:40 AM
this is going to do a lot better in the gen III internal section man, try asking patrick
SpecialK Dec 21, 2007 11:43 AM
https://ls1tech.com/forums/generation-iv-internal-engine/828468-prc-stage-1-5-vs-afr-225-a.html
I know your budget is $1000 bean but seriously take a look in there.
You still haven't' decided on a cam yet though. I wouldn't recommend a head till I know what kinda cam you're planning on running. If your going to run a T Rex style cam go for big flow numbers in the .500 to .600 range. If your goign to run a "baby" cam run somethign that has better flow numbers down low.
© 2026 MH Sub I, LLC dba Internet Brands
