LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   ARH and Texas-speed TD's ??? (https://ls1tech.com/forums/generation-iii-external-engine/835022-arh-texas-speed-tds.html)
2002RamAir Dec 25, 2007 11:51 AM
Does anyone know if the ARH and the texas speed true duals will work together?? Looking to take the plunge into headers again...had qtp a couple years ago..they were great except for their ypipe, but going with ARH this time around...just dont know if I wanna go y-pipe or true duals...
Thanks
LS1-NAVY Dec 25, 2007 03:11 PM
you might have to do some moding to make them fit but it should work
willyss01 Dec 25, 2007 04:47 PM
is there anyother true dual setup that would go with the arh headers
jrob56 Dec 25, 2007 04:55 PM
i dont see why it wouldnt
cals400ex Dec 26, 2007 01:12 AM
i dont' think it will be a direct fit but i could be wrong.
dug Dec 26, 2007 02:22 AM
i think theyre made to fit the pacesetters. ive heard of people using themwith different headers like hooker and qtp
A. R. HEADERS Dec 26, 2007 08:47 AM
2002RamAir, ARH's aren't a direct fit with anything other than our own Y-pipe. I can tell you that we can custom size our Y-pipe to handle nearly any HP level. Because it's a true 2 into 1 merge you won't be making any compimises with regards to power. If you have questions regarding ARH header and Y-pipes i highly recommend you call me directly and I'll get you all set up with whatever info/parts you may need. Thanks
Nick
DocEwww Feb 28, 2008 11:16 AM
bump.... j/w if anyone is running this setup. I'm currently running Kooks stepped and might be switching to ARH due to my Kooks being damaged.
© 2026 MH Sub I, LLC dba Internet Brands
