My belt squeeks bad when I shift at high RPMs I'm not real sure what is causing this problem. My belt is squeeking bad when ever I shift up at elevated rpms. Has this happened to anyone else? Not sure if I should just try a new belt, get some belt dressing, or get a adjustable tensioner pulley. Any suggestions? I don't have A/C so it's something on the main serpentine. Thanks |
Re: My belt squeeks bad when I shift at high RPMs ttt |
Re: My belt squeeks bad when I shift at high RPMs Are you sure it's not the trans??? |
Re: My belt squeeks bad when I shift at high RPMs The belt is probably loose. If it has a glazed look on it, then get a new belt. |
Re: My belt squeeks bad when I shift at high RPMs dont rule out a throw out bearing |
Re: My belt squeeks bad when I shift at high RPMs I think that the belt is loose too but it uses the stock spring tensioner. I'm sure it's not my trans and it's definitely not a throwout bearing(it's auto). I'm going to pick up some belt dressing tonight and give it a shot. |
Re: My belt squeeks bad when I shift at high RPMs DO NOT PUT BELT DRESSING ON IT AT ALL! You will end up with a chirppy sound at idle and a hell of alot of squeal at high RPM's. You putting dressing on the pullies will make it messy and sticky as well. Don't cheap out on a new belt. I'm 99% sure that's all you need. Using dressing to get by is like using engine oil on your dash till you get a chance to buy some detail stuff! Dressing is o.k. on k-cars and Fords. :barf: |
Re: My belt squeeks bad when I shift at high RPMs My 99 Z28 did that when I first got it. I put a new belt on it with no luck. I then put a new factory tensioner on and it totally went away. I would probably start by replacing the belt and then the tensioner or go with an adjustable tensioner. Hope this helps... |
Re: My belt squeeks bad when I shift at high RPMs I suppose I'll try a new tensioner and another new belt. The belt only has about 300 miles on it. |
© 2024 MH Sub I, LLC dba Internet Brands
