View Poll Results: How loud compared to Magnaflow/ory/longtubes type setup
way louder and will get you in to trouble
2
14.29%
little bit louder and wont get you in to trouble
9
64.29%
little bit louder and will get you in to trouble
0
0%
about the same as an ORY/catback setup
3
21.43%
Voters: 14. You may not vote on this poll
How loud would 2.5" duals over the axle 1 chamber flows w/ cats be?
Old 01-06-2008, 10:25 PM
CAMAROZ28AQUINO's Avatar
Post How loud would 2.5" duals over the axle 1 chamber flows w/ cats be?
Going nuts trying to pick the perfect set-up for me. Its a DD street car that i dont want to get in trouble with the cops. System will be longtubes, then 3" magnaflow metallic spun cats, then stepped down to 2.5" duals w/x-pipe ran all the way out the back through a 228/232 110lsa cam. How loud would this setup be compared to ORY systems such as magnaflow/ borla? Would this get me in to trouble with the cops? no emissions testing here.
Old 01-06-2008, 11:06 PM
Tech Resident
ChocoTaco369's Avatar
I would think it would definitely be louder as those little race mufflers are going to be no match for a full-size muffler when it comes to quieting exhaust.
It'll definitely be a bit louder. Whether or not you'll get in trouble...well, that depends. If you go WOT past cops...well, you'll probably get in trouble. If you drive like a normal person (under 2500 rpm's), you'll probably be fine.
Old 01-06-2008, 11:10 PM
02NBMWS6's Avatar
it'll be ALOT louder. Not what id want for a dd street car
Old 01-07-2008, 11:21 AM
ryanfx's Avatar
over the axle, WITH cats... you'll be fine. I bet you'll be surprised how quiet it is.
(not saying it's going to be "quiet" but it'll be quieter than you expect.)
Old 01-07-2008, 04:58 PM
TORCHD 02 TA's Avatar
C'mon do it! You have PMd me many times, and i have given you all my vids.......
DO IT!!!!!!
Old 01-07-2008, 05:03 PM
RareBreed0295's Avatar
I would think the cats would quiet it down a good bit. Only way to find out is to do it.
Old 01-07-2008, 05:19 PM
DO IT!!!!!!
hahaha i want to but i just dont want it too loud where i get into trouble with it..i want it so people can definetley hear it, but i dont want it unbearabley loud. Im undecided between 4x9's or 1 chambers.
Old 01-07-2008, 05:51 PM
I know what you mean..
I did give you vids on both my MagnaPacks and 1 Chambers.... Now you need to decide
Let me know if you need more help
Old 01-07-2008, 09:36 PM
^ thanks man, i probably will need some more convincing. I personally dont mind if its a bit loud, its just the 5-0 im worried about. If its close to an ORY/catback setup ill be fine, even if its a bit louder i should manage if i keep out of it
Old 01-08-2008, 04:11 PM
you've heard that my car is cammd... i pull up next to cops and they give me the
JUST DO IT ALREADY
Old 01-08-2008, 04:14 PM
BlueBird346's Avatar
I think it depends on how strict the cops in your area are...
Old 01-08-2008, 04:15 PM
JUST DO IT ALREADY
That would make my day.
Old 01-08-2008, 04:16 PM
What would
Old 01-08-2008, 04:32 PM
The cops doing that.
Old 01-08-2008, 04:52 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
SAME HERE..
Old 01-08-2008, 08:36 PM
i donno guys...what sounds better magnaflow 4x9s or 1 chambers
Old 01-08-2008, 08:43 PM
You have my vids, listen to them again and TURN THE SOUND UP and decide.. it is as easy as that
Old 01-08-2008, 09:37 PM
^^^^ trust me i have many many times. Quick question, at idle do you think u can be heard from a 100 feet away? Also do the 1 chambers give a high pitched refined note like a vette or not?
Old 01-08-2008, 09:57 PM
well let me put it this way.. I live in an apartment complex... You can hear my car idling from the inside..
With the H you will get a low, deep bassy tone.. vettes have an x pipe which is a higher pitched tone..
On my vid with the MagnaPacks, i had an X pipe.. and the H went on with the 1 chambers
Old 01-09-2008, 01:27 PM
02NBMWS6's Avatar
The magnaflows have a very smooth high pitched tone at high rpms. That's exactly how I used to describe them. They are really deep and bassy at idle, but the tone completely changes at high rpms. I cant speak for the 1 chambers but id doubt that
I LOVED the high pitched tone of my x pipe 4x9 setup at anything over 4500 rpms
