LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   BBK vs NW tb's (https://ls1tech.com/forums/generation-iii-external-engine/844414-bbk-vs-nw-tbs.html)
johnnydje Jan 12, 2008 04:41 PM
BBK vs NW tb's
looking for the better one to buy,bbk 80 or nick williams 90 ?whats a fair price?
2000PewterZ28 Jan 12, 2008 05:04 PM
Don't forget about the PTM 90MM TB. You can get it for a great price.
orangeapeel Jan 12, 2008 05:04 PM
Well, they aren't alike in any way except for being a throttle body. What are you wanting to do with this setup? I would vote for NW either way. Ask a sponsor about pricing. ------------>>>>>>>
johnnydje Jan 12, 2008 05:11 PM
just getting started,right now gear/intake/later in spring cam.just looking for alittle more go-juice thats all,daily driver.
orangeapeel Jan 12, 2008 05:13 PM
What intake are you planning on running? LS6? FAST? BBK?
johnnydje Jan 12, 2008 05:16 PM
bbk looks real good on numbers.BBK.
RareBreed0295 Jan 12, 2008 05:19 PM
Are you planning on running the Ls6 or the fast???
orangeapeel Jan 12, 2008 05:22 PM
I would stick with an LS6 intake and a ported stock TB + a mild cam. That is a budget setup that will rock. If you plan on going with heads that are running oversized valves consider bigger. Not that you won't benefit from it now going 90/90 or 80/90.
Nick Williams Jan 12, 2008 05:46 PM
For now I think you should just get your stock throttle body ported. Later on when you get your cam installed, then you should start to consider a 90mm intake and throttle body and heads. Just like Orangeapeel said.
35th SS Jan 12, 2008 08:18 PM
running a stock ported one witha ls6 intake on my blk one for now.soon will have a NW90/FAST 90 in there too.
sidewayz28 Jan 12, 2008 08:21 PM
cheaper...PTM 90MM TB
orangeapeel Jan 12, 2008 08:56 PM
I would suggest less on skimping with a PTM and go for the NW when the time comes.
Mike @ New Era Jan 13, 2008 04:17 PM
We have a sale going right now on porting stock throttle bodies , $65 !!! Sale ends at the end of this month . We also have the BBK 80mm and 85mm throttle bodies in stock and on sale at $299 for the 80 mm and $329 for the 85mm , and the BBK Intake manifolds are $399 and also in stock .
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Shawn @ VA Speed Jan 13, 2008 07:33 PM
bbk piece leaves a little to be desired,stock tb works great on ls6 intake-anything up to mid 400's rwhp,after that fast 90 with nw 90
WhosNXT Jan 13, 2008 08:30 PM
I agree, take some time on saturday afternoon and port your stocker. Then when you do your h/c setup do your intake and tb at the same time.
© 2026 MH Sub I, LLC dba Internet Brands
