LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   first time with a dremel. how'd i do (https://ls1tech.com/forums/generation-iii-external-engine/844436-first-time-dremel-howd-i-do.html)
scottie dont Jan 12, 2008 05:16 PM
got bored today and started messin with some more new parts. let me know what you think
https://www.fquick.com/images/vehicl.../585390819.jpg
https://www.fquick.com/images/vehicl.../585390820.jpg
https://www.fquick.com/images/vehicl.../585390822.jpg
https://www.fquick.com/images/vehicl.../585390844.jpg
https://www.fquick.com/images/vehicl.../585390823.jpg
https://www.fquick.com/images/vehicl.../585390825.jpg
- Scottie
99mongooSS Jan 12, 2008 05:59 PM
nice Id like to see how that does in comparison to the factory unmodified version.
Where did you get the MAF ends?
scottie dont Jan 12, 2008 06:12 PM
the maf end are from tbyrne motorsports. and they fit very nicely. i cant wait to see how much this helps
Black99CamaroSS Jan 12, 2008 06:35 PM
You could of ported your maf ends and saved the 40 or so bucks.
Also get ready to be flamed for messing with your stock maf.:secret2:
orangeapeel Jan 12, 2008 06:40 PM
All I can say is "Scottie Don't" port your MAF! You could end up with some vicious A/F problems. Also if you can feel that help you out you may want to check and see how hot your car is running when it is mega-leaned out.
scottie dont Jan 12, 2008 06:47 PM
i have a backup. but the car has always thrown the MAF sensor voltage low code since i've owned it. its getting tuned so i figure ill get it adjusted then.
99mongooSS Jan 12, 2008 10:49 PM
so the bar that is usually covered by the factory MAF end housing should not be ported away? I didnt see anything altered about the sensors I just saw what looked like a support bar got chopped off. That could make it run lean?
© 2026 MH Sub I, LLC dba Internet Brands
