AC Delete
Old Jan 17, 2008 | 12:59 AM
  #81
waterbug1999's Avatar
Originally Posted by Ilikeppie
is that inside the box?
It runs out thru the box/firewall and runs into the bundle of wires and towards the front of the car. There is a little cylinder it runs to which from what heard, helps hold a little more vacum to turn the different vent settings.
Old Jan 17, 2008 | 01:04 AM
  #82
Ilikeppie's Avatar
gotcha ill be sure to watch out for that little bugga
Old Jan 17, 2008 | 01:07 AM
  #83
Well, your going to actually have to cut it (unless you can find where it attaches and try to slip it off) to get the new piece on, then reconnect it running thru the same hole as the two heater connects are.. But, just dont cut it in 5 pieces like I did.
Old Jan 17, 2008 | 02:53 AM
  #84
SIC LSX's Avatar
I pulled mine off at the end of summer because i blew and line. Hell i may keep it off it looks so much cleaner under the hood, But i will not take out the whole box i just put some rubber caps on the AC ends Also with the AC condenser gone my lid/air filter gets twice the air it used to
Old Jan 17, 2008 | 02:06 PM
  #85
You still have the whole thing attached to the firewall though.
Old Jan 17, 2008 | 03:05 PM
  #86
Ilikeppie's Avatar
i think ill leave the box too i wont loose much weight takin it off and this way i can hook the ac back up with out much work if i want to
Old Jan 17, 2008 | 03:30 PM
  #87
chrs1313's Avatar
exactly what i did...kept the box...whole ac is worth 33lbs
Old Jan 17, 2008 | 03:31 PM
  #88
Cool deal... I never used mine so I took it compeltely out to help with changing plugs, etc. I dont drive mine but on the weekends and its not my DD...
Here might be a better view of the room.
Old Jan 17, 2008 | 04:03 PM
  #89
SIC LSX's Avatar
mine isnt a full tim drag can and get driven year round. So if i want to throw the AC on for a summer road tirp i can
Old Jan 17, 2008 | 11:15 PM
  #90
Ilikeppie's Avatar
yea i would love to do it that way but i dont wanna burn my bridges ya know what i mean
Old Jan 18, 2008 | 01:50 AM
  #91
CO99Z28Vert's Avatar
awesome im hoping for low 11's but have no idea what it will do especially in the mile high city
Ilikeppie just remember the elevation is going to screw you badly. Dont get upset at a low 12 second pass because remember that would be an 11 second pass at sea level.
Right now I bet im running mid 14's. I will see when I run this year.
Old Jan 18, 2008 | 03:32 AM
  #92
Ilikeppie's Avatar
yea im worried that the elevation will make my car a lot slower but i hope this stuff is enough to bring it to 11's i think i just aquired a ls6 intake
Old Feb 24, 2008 | 04:01 PM
  #93
AKNUFMAN's Avatar
Default Delete Ac
Does anyone know where to get a sheet metal plate to cover up the hole if you remove the ac from a 76 Nova? Thanks..........................
Old Feb 24, 2008 | 05:35 PM
  #94
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Best bet is to make your own. My roommate just made one for his 73 Nova
Old Jul 25, 2008 | 08:08 PM
  #95
FireSilverLullaby's Avatar
does anyone know where the a/c system sucks the air in from?
I deleted my a/c and when i turn the fan on the air always seems to be alot warmer than outside. just trying to see if theirs a way to make the air a lil colder for when im in traffic or something.
Old Jul 30, 2008 | 09:22 PM
  #96
jetlag's Avatar
So, if I want to remove the box with the engine in the car... It has to be completely destroyed?
Old Jul 30, 2008 | 09:38 PM
  #97
WS7_FORMULA's Avatar
i just did my delete ac today, pretty easy. In 30 minutes it was done
Old Jul 30, 2008 | 11:26 PM
  #98
All the way to the firewall?
Old Jul 30, 2008 | 11:50 PM
  #99
bww3588's Avatar
highly doubt it, it took me 30 minutes to figure out how i was going to cut the box off the wall.
Old Jul 31, 2008 | 12:06 AM
  #100
oh hell no. haha ill do that later, too much and besides i need the heat for winter, its almost near..........
