EGR question
Old Jul 6, 2003 | 09:32 PM
2Xtreme's Avatar
Default EGR question
Is there any way I van get ride of the whole EGR system. Can it be done without getting a ses light.;
Old Jul 6, 2003 | 11:31 PM
felton316's Avatar
Default Re: EGR question
You will need Ls1-edit and turn the EGR codes to not displat 'SES'
Old Jul 6, 2003 | 11:38 PM
PongoX11's Avatar
Yeah, no way to get around it throwing a code as far as I know. Have had an SES light on for the last few months after pulling the AIR and EGR systems--without any problems.
Here is a good step by step site for pulling the EGR
http://www.ls1camaro.net/sections.ph...e&artid=70
Old Jul 7, 2003 | 12:40 AM
Smoke_Ford's Avatar
You need to remove the EGR system, get EGR block of plates for the manifold, and a 35 mm freeze plug for the intake. Then, either use LS1edit to remove the code, or have it tuned. (Normally during tuning they remove this code.)
Old Jul 7, 2003 | 12:41 AM
Smoke_Ford's Avatar
Oh, BTW, save the canister, it is worth alot of money! Although the temptation to launch it into your neighbors yard via a 3-man water ballon launcher is very tempting...
Old Jul 7, 2003 | 04:50 PM
2Xtreme's Avatar
How do you remave the air system, is it hard, does it have any benefits, and where can i get instructions on how to do this, and will it help clean up the engine compartment.
Old Jul 8, 2003 | 10:01 PM
blackend02's Avatar
I have a ? if i am running LT`s and no cats but still have the air system hooked up to the headers would that mess up my ltft`s?
Old Jul 8, 2003 | 10:23 PM
FrankSS's Avatar
all the air system is for is to get the cats heated up faster when you start your car...therefore no cats, no need for air... and shouldnt hurt any tuning at all.......
Old Jul 8, 2003 | 10:24 PM
FrankSS's Avatar
oh and i just thought of this, if there are any fuses for the egr and air system, can we remove them and have it not throw a code that way??
Old Jul 9, 2003 | 11:49 AM
whitez71's Avatar
There is probably not a fuse for the EGR/AIR system. If there was one and you pulled the fuse it would set of the light because the system would not have any power making it inoperative.
Old Jul 9, 2003 | 12:24 PM
WS6snake-eater's Avatar
Is the EGR/AIR system all part of the same thing? I'm trying to install my headers, and there is not place to bolt this stuff into.
Old Jul 9, 2003 | 12:30 PM
ok just read the how to that is posted in this thread. Thanks guys. I guess I can delete my other post now.
