What to do with $2000?
Old Feb 26, 2008 | 09:20 PM
Soul TKR's Avatar
buy some heads... get the expensive part over with
Old Feb 26, 2008 | 09:26 PM
transam69230's Avatar
I read your list at the beginning, and then i read you want to put a cam in, i am going to suggest a rearend too! All those suspension parts if you are going to do much. If your drag racing witch i assume you are, a rearend is going to give you a way better benifit. I am installed stock 243 castings heads, a cam, a forged motor, built trans, trq converter, and a bunch of other go fast parts and my car ripped, but for only about 2 months because the rearend is garbage now thanks to my mickeys. I am afriad to drive the car now because i think the rearend could go at anytime. Either which way you go i guess your that much closer to going faster, but use the $2000 dollars wisely.
Old Feb 26, 2008 | 10:54 PM
fastz99's Avatar
Originally Posted by M-Ten
well, what are your plans for the car.. hard to actually recommend upgrades when we don't know what you want..
want to keep it n/a?
do you take it to the strip? what??
My goal is to have a 10 sec street car for the summer. I plan on running nitrous but that is way in the future. I want to do a cam only (G5x3 cam) for awhile then save up for some patriot heads. I was thinking of buying with the $2000 full exhaust and Koni shocks and Strano Springs. What do you guys think? Is this a weird place to start?
Old Feb 26, 2008 | 11:16 PM
M-Ten's Avatar
Well, unless you plan on going to a different rear end, I would have to recommend putting some 4.10's in.. for ~250 that's the best bang for the buck you can get IMO
Maybe do that, and a nice set of LT's (QTP's or Kooks) and some true duals. That should put you right around your $2000 budget.
If you plan on switching out the rear end, and want to get it out of the way, then I'd say do it now like a couple others have said.
But if you want to hold off on that and get something else, you can't go wrong building up your suspension either (Springs, shocks, LCA's, torque arm?).. It will preserve your current rear end by eliminating wheel hop and also will be a HUGE improvement you'll want to do anyway..
One more thought is some new rims/tires.. or just new tires if you like your rims. Getting a nice set of DR's will also help avoid banging around your rear end, and is also something you'll have to do...
You'll be happy with any of these routes, but the way I did it was I got some QTP's and a 2.5" X, just got my nitto 315's and 17" TTM's in the mail yesterday, and next I'll be building up the suspension pretty heavily because I'm getting some pretty bad wheel hop and want to lower it..
That's just my opinion though
Old Feb 26, 2008 | 11:23 PM
fastz99's Avatar
I am thinking of getting a rear end that is not a bad idea. Then I would not have to worry about breaking it and i could also get 4.10 gears with it. That would be all my money right there though. Which rear end do people usually recommend? 9inch or 12 bolt?
Old Feb 27, 2008 | 12:00 AM
M-Ten's Avatar
9" is the norm for 6 speed cars, 12 bolt for autos. The rear end is gonna cost you a little more than $2000 though. Also, I'm not sure what the average is on the install.
Old Feb 27, 2008 | 12:11 AM
Detoxx03's Avatar
Send it to me so I can get some heads, naw but suspension is always a good thing.
Old Feb 27, 2008 | 01:12 AM
jmilz28's Avatar
Not at all. If you plan on keeping this car and you drive it daily, this is the best place to start. Me personally, I'd do the Koni shocks and the sway bars. Those are the two weakest links on these cars for day to day spirited driving. I also wish I had nutted up for a quality exhaust like Kooks or ARH. I will end up redoing my exhaust soon and shocks too. They were both major improvements but having experienced better and with plans to keep this car - do it once, do it right. Also keep money in the kitty for filters, fluids, plugs, and a clutch. A smart move would be to upgrade brakes too. Hawk pads and Brembo blanks along with a fluid flush, at a minimum. These cars have such a good motor/tranny from the factory yet people do engine mods first, making for an unsafe car. You need a balanced, safe car that can control the power. Besides, power slides are more fun when they are predictable. Bottom line, a safe controllable car is more fun. Do the suspension right and you can go faster AND be safer because you have better control.
Shocks
Sway bars
Brakes
TA girdle with stud kit
Quality exhaust
Do it once, do it right, build the foundation for an all around awesome car.
Old Feb 27, 2008 | 01:54 AM
98nosz28's Avatar
I would go with a H/C from Texas speed. I am still running the stock suspension on my H/C/I car and it is a blast to drive. If i would have spent the moeny on supsension first I would still have a slow car that handles great. Or like said b4 go with a rearend and put slicks on it and have a pretty fast car also.
Old Feb 27, 2008 | 09:06 AM
WS6_00's Avatar
don't put money into that 10 bolt rear end u have now, if u want gears then wait until u can afford a 9". putting money in the 10bolt is a waste.
Old Feb 27, 2008 | 02:40 PM
fastz99's Avatar
I know it would still be slow if i just did suspension, but you cant go fast if you cant plant any of that power to the ground.
Old Feb 27, 2008 | 03:14 PM
  #32
jmilz28's Avatar
If this is your daily driver, don't do go fast parts first. Go fast parts make **** break. Upgrading your suspension and brakes and exhaust has zero effect on reliability and make a nice platform for future mods. If this is a weekend toy and not your daily driver, then you can make a case for go fast parts. Fact is, the PROPER suspension mods will also protect the 10 bolt. Go fast parts will only further strain the rear. Is this your daily driver/only car?
Old Feb 27, 2008 | 03:16 PM
  #33
96lt1ss's Avatar
I would heads and cam it.
Old Feb 27, 2008 | 05:57 PM
  #34
fastz99's Avatar
This is my daily driver car for the summer only. I store it in the winter. It has never seen snow.
Old Feb 28, 2008 | 12:10 AM
  #35
jmilz28's Avatar
Gotcha. If you have another car, knock yourself out. Shocks are still the single biggest improvement you can make to these cars. You benefit in all areas and sacrifice nothing. In hindsight, if I had to do it over again, with $2grand I would do:
Koni shocks
Strano bars
shifter
Exhaust
Alilgnment
It will make the car better in every way, giving up nothing. It will also be so much more fun to drive, it'll be ridiculous. THEN heads and cam it (and brakes). Make sure you have good tires, too many folks take this for granted or cheap out.
Old Feb 28, 2008 | 11:43 AM
  #36
fastz99's Avatar
Koni shocks
Strano bars
shifter
Exhaust
Alilgnment
I have some good tires that i bought from the tire rack awhile back. I am going to have to get new ones, but I am going to save up for new rims and do it all at the same time. Otherwise i will have to buy tire again. How do you like the Pro5.0 shifter with the LSS handle? I am going to be getting the Pro 5.0 and dont know if i should get the shorter handle.
Old Feb 28, 2008 | 12:13 PM
  #37
M-Ten's Avatar
definitely get the shorter handle, i have the 5.0 and lss and it feels awesome
Old Feb 29, 2008 | 12:43 AM
  #38
5.slow99's Avatar
LT's, gears, stall, intake, TB
Old Feb 29, 2008 | 11:12 AM
  #39
M-Ten's Avatar
he's a 6 speed
Old Feb 29, 2008 | 11:16 AM
  #40
plaf713's Avatar
12 bolt or 9 inch, make your car reliable first then make it fast
