What's this connector used for?
Old Mar 12, 2008 | 09:57 PM
Tri5Nerd's Avatar
Default What's this connector used for?
I think this is a connector for a vacuum line but don't know what's connected to it. It's on the back of the intake manifold close to the MAP sensor. I know the larger connector has a line that goes to the brake booster.
Old Mar 12, 2008 | 11:01 PM
massls1guy's Avatar
There is a picture of the stock equivalent just a few posts up. I think that is the vacuum source for HVAC switching but I'm not sure.
https://ls1tech.com/forums/generation-iii-external-engine/881472-broke-sensor-need-help.html
Old Mar 12, 2008 | 11:10 PM
Tri5Nerd's Avatar
Will this cause a vacuum leak, can it be plugged if I'm using a HVAC?
https://ls1tech.com/forums/showthread.php?t=881472
Old Mar 12, 2008 | 11:14 PM
405HP_Z06's Avatar
This is the vacuum connection that operates the HVAC vent doors inside the passenger compartment. If your car is not A/C or heater equipped this can be capped off. Either way, it must have a hose or cap on it or you will have a significant vacuum leak.
Old Mar 13, 2008 | 09:52 AM
Tri5Nerd's Avatar
Thanks for the help, I'll just cap it now maybe the engine will idle better.
Old Mar 13, 2008 | 11:05 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
With out this vacuum source hooked up you will not be able to switch the vent settings in your car, it will default to defrost only.
