Headers Looking to get headers which one should i go with SLP or the FLP.Should i go with cats or with out. |
Re: Headers Out of those two the FLP's. But also consider the Hooker, Jet Hot and Pacesetters with hooker off-road pipe. You can't beat the hp gain for the money. |
Re: Headers is there that big of a diff. in the hp in the two. is it true that the slp is not all that they made it out to be |
Re: Headers Besides performance issues, SLP's hang low. I have to take speed bumps diagonally all the time. :( |
Re: Headers so u get more out of the flps. the slp is not that good and it hangs too low. |
Re: Headers If I had to do it over, I'd get Hookers with a QTP Dual Electric cut-out Y-pipe. |
Re: Headers thanks i guess i will look in to that set up i was leaning more towards the flps cause i had heard some bad things about the slp and alot good about the flps |
Re: Headers I got hooker headers coming...I've heard that alot of people have to take a dremel and grind down some of the welds on the inside cause hooker welding is a little sloppy..... but thats no big deal....great price...great power...good sound....:burn: |
Re: Headers Whats the difference when running with cats or without??? More HP, Louder??? |
Re: Headers Whats the difference when running with cats or without??? More HP, Louder??? First of all there's a legal dilemma one must face. Once faced: HP will increase w/o cats. Car will get louder also. |
Re: Headers if you have the $$..consider Kooks or QTP headers |
Re: Headers Sloppy weld?... My Hooker SC LT from Summit was in perfect condition, with perfect weld. |
Re: Headers slp gave me 25rwhp, dynoproven... so i really don't think that the SLP are bad at all... |
Re: Headers I've heard that alot of people have to take a dremel and grind down some of the welds on the inside cause hooker welding is a little sloppy. Sloppy weld?... My Hooker SC LT from Summit was in perfect condition, with perfect weld. |
Re: Headers I got hooker headers coming...I've heard that alot of people have to take a dremel and grind down some of the welds on the inside cause hooker welding is a little sloppy..... but thats no big deal....great price...great power...good sound....:burn: O2 bung misaligned...drill it out...retap Flange wasn't level...file it down 1/4 inch spot wasn't welded...get coated headers welded up so they won't leak collectors didn't align properly with Mufflex Y pipe. Once there installed they are pretty decent. BTW Mine looked good a first glance... |
Re: Headers I have SLP longtubes. Haven't dyno'ed yet..but I will in a month or two. All I can is that I sure could feel a big difference after installing them. I'm lowered and they do hang low but it hasn't been a problem for me. I very satisfied with them. |
© 2024 MH Sub I, LLC dba Internet Brands
