Hooker's are on!!!
Old Aug 3, 2003 | 03:12 PM
Onyx Z's Avatar
Default Hooker's are on!!!
Just finished the install of my Hooker LT's and ORY-Pipe. The install went pretty easy, just took a while.
Through the Flowmaster it sounds like ****, it's has a really high pitched sound at low RPM's so a new catback is needed.
There is definately a SOTP difference in power.
Just one problem, when I'm taking off, not launching, just driving noraml, the ABS INOP and LOW TRAC light come on for a second and then go off. The tires aren't spinning and the brakes work fine. Anyone else had this problem, if so what did you do to fix it?
Thanks
Ryan
Old Aug 3, 2003 | 04:29 PM
jg2k2z's Avatar
Default Re: Hooker's are on!!!
mine went on without any probs...and I am not experiencing anything that you are describing...Good Luck...BTW where did you install your cutout at? I have the o/r y too and am looking at getting this...thanks
John
Old Aug 3, 2003 | 09:12 PM
Onyx Z's Avatar
My cutout is right under the rear seat hump in the I-Pipe.
Ryan
