View Poll Results: HP gain of custom ram air over STOCK setup...Track results tomorrow
Voters: 94. You may not vote on this poll
MY RAM AIR VS. stock setup...How much HP Dif...TRACK RESULTS TOM.
#181
"Ram Air' is supposed to work by raising the air pressure in the intake manifold. If you want to see the non-effects just log MAPs to the decimal point under WOT during identical barometric pressure, temp, rpm, etc. Any effects can only be from a closer to ambient temperature of air coming in. At vehicle speeds RA plays to a myth.
https://ls1tech.com/forums/drag-raci...ome-tests.html
There is a reason every single sport bikes has a ram air induction setup and also look to Prostock...granted they get even more gains going 200mph but most of our cars are in the 110-140mph range
#182
Heres my ram air set up. 4" aluminum pipe, IAT sensor underneath close to TB, removed MAF and speed density tuned. Also cut the "slit" in the hood to maximize air flow. 7"to4" velocity stack for track then have a filter for street driving. Key on engine off the MAP sensor saw 87 kpa (el paso, TX 5800ft DA), with SLP lid and no filter at WOT I saw on average 89 kpa, with this set up I would see on average 95 kpa. Pretty big difference.
#184
maybe a dumb question here : ive seen where you guys cut the baffles out of the factory hood on a ws6 for the true "ram air effect".. Do you also do the air box mod as well? Or is it one or the other(on ws6 )? Or both?
#186
#188
Originally Posted by BrntWS6
Brian greens BG ram air mod picked up 2 tenths and 2 mph tested by a magazine back in like 2004. Ram air definately works.
