what do you think about this exhaust idea
sprial flow off y-pipe???
edelbrock long tubes, edelbrock off road y-pipe, then a cut out on the tip of the y-pipe then on the cut out a moroso sprial flow.?
would that be louder then my lm II cat back?
regardless i want the cut out as close to the y-pipe is possible. but as fas as the sprial flow i dont know if i should put a pice of pipe between the cut out and the sprial flow or if i should put a pice after the sprial flow or both?
any ways will the dumped sprial flow be quietier then the lm II cat back, and is the sprial flow the quietest bullet?
I think it sounds alright. The cutout is going to be louder than your LM II I would think anyways. Try it and get a sound clip. Keep your old **** just incase you don't like it.
