what's the max ls6 throttle body size? i need to know the biggest size throttle body that you can get is it 80mm? |
You can get a 100mm from sponsors on here. Probably 105+ now. |
If you're asking what the biggest size will bolt to a stock intake, the Professional Products 85MM comes with an adapter plate that will let you bolt it on. Thats the biggest one for a stock intake. |
anything bigger than stock is a waste since the intake manifold opening is only 75mm |
| All times are GMT -5. The time now is 10:19 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
