ls6 intake install-oil pressure pegged out max
Old 06-08-2008, 06:16 AM
alc80's Avatar
Default ls6 intake install-oil pressure pegged out max
just did the ls6 intake swap on a 2000 a4 and now the oil pressure gauge is pegged out passed 80....wtf. if i broke the oil sensor everyone has a problem with, wouldnt it read no pressure?
any ideas?
Old 06-08-2008, 09:30 AM
98hc4mula's Avatar
you broke it need to go buy a new one and install it. that happens alot
Old 06-08-2008, 10:06 AM
bigti99a's Avatar
yeah i broke mine. you will need a DEEP 27mm or 1 1/16th socket. and i mean DEEP. not a hard thing to change though.
Old 06-08-2008, 05:36 PM
alc80's Avatar
ehhh oh well. get it changed soon enough, hopefully without taking the manifold off again. thanks
Old 06-09-2008, 03:42 PM
382ssz28's Avatar
Snap-On socket part# A120. 1 1/16" with the right hex. This is what I put mine on with, plus, it will do alot of other sensors. Good luck!
Old 06-10-2008, 01:24 AM
alc80's Avatar
were you able to do yours w/o removing the manifold again?
Old 06-10-2008, 01:38 PM
felton316's Avatar
If its broken it will read 0 pressure. If you forget to plug it in, it will read MAX pressure. Check to make sure its plugged in before buying a new one.
