Just threw on an intake NO OIL PRESSURE!!!
Old 06-10-2008, 09:55 AM
Bpjr07's Avatar
Exclamation Just threw on an intake NO OIL PRESSURE!!!
well i put a bbk intake in and checked all the connections it all looked fine and turned on my car for 10 seconds and saw that there was no oil pressure going through it.
i turned it of and here i am what can the problem be and how can i fix it.
thanks
Old 06-10-2008, 09:57 AM
sschkade's Avatar
Did you break the oil pressure sending unit? It's on the back of the block, closer to the drivers side bank.
Common mistake when putting on an intake... I think you need a 1" deep socket to take it off and put the new one on.
Old 06-10-2008, 10:03 AM
Bpjr07's Avatar
that unit doesn't plug into the intake right?
i checked it before i threw it in it was ok but i think the brake booster hose might have pushed it out wen it wen in then!
Old 06-10-2008, 10:19 AM
slt200mph's Avatar
They are very EZ to break ... bet that is your problem ..
99blancoSS's Avatar
All you have to do is bump it and it breaks sometimes.
Old 06-10-2008, 10:21 AM
Mr. Brett's Avatar
It doesn't plug into the intake, but the brake booster hose on the back of the intake has to go over the sending unit when you put it on. Pretty much everybody breaks it at least once. Time to take the intake back off.....
Old 06-10-2008, 10:32 AM
tylerdj's Avatar
You broke the oil pressure sending unit...it sits right behind the intake and breaks pretty easily when you move the intake around.
Old 06-10-2008, 11:04 AM
Rowin Gearz's Avatar
You def. broke the oil pressure sending unit. I did the same thing on my '01 SS when I swapped to a fast 90/90. It was a PITA to replace it on the back of the engine becasue it broke off so close to the base of the unit. Not fun!
Old 06-10-2008, 11:05 AM
1320 killer's Avatar
This is actually a pretty common problem. it happens all the time. you can pick up a oil pressure sending unit from your local parts store.
Old 06-10-2008, 11:13 AM
Bpjr07's Avatar
i took pics wen i took the inktake of, i see the unit in good shape but i dont remember moving the hose over it! DAmn well 30 bucks and its here tomorrow said Autozone.
Old 06-10-2008, 11:28 AM
00_transam_vert's Avatar
Another one bites the dust.
Old 06-10-2008, 08:16 PM
SweeTbone's Avatar
Personally, I would only buy a sender from GM and not Autozone. Seems like I've read of people having problems with aftermarket senders.
Old 06-10-2008, 08:48 PM
Mikes96z's Avatar
oil pressure sending unit....
Old 06-10-2008, 09:57 PM
Black01M6SS's Avatar
Nice job noticing the lack of pressure and shutting the car off quickly.
I had a customer today drive their car ~30 miles to the dealership and tell me it doesn't have any oil pressure. "The sending unit was bad." The customer actually thought it didn't have oil pressure though...and drove the car...
Old 06-11-2008, 12:52 AM
Bpjr07's Avatar
Wow i was worried that i might have fucked something up....
there should be no problems right?
Old 06-11-2008, 01:42 AM
BayAreaSS's Avatar
The damn oil pressure sending unit strikes again LOL
Old 06-11-2008, 07:06 AM
Mikes96z's Avatar
It needs to be replaced. You can't chuck it up to a bad sending unit and leave it.
