would new ceramic headers mess up o2's??? i just ordered some pacesetter ceramic long tubes and ORY and i heard from some people that you must let the ceramic in the header break. if the o2's are in during the break in the o2 will be damaged from the harmful fumes. is this true?? so should i disconnect the front o2's and run open loop mode for a few heat cycles?? thanks guys |
anybody??? |
I didn't, they work fine |
Originally Posted by ae13291
(Post 9551297)
forgive me, but they are ceramic COATED? Doesnt that mean the outside of the header? If so, then your O2 sensors will be fine... |
Originally Posted by ravensfan
(Post 9551926)
Originally Posted by Pntbll309
(Post 9551916)
Correct. The Ceramic will burn off some, that can cause the o2's to go bad. Chances arent high tho. But it could do it. As for running in open loop, not sure.But the car would run like shit, and itll take some time to burn off. Also since your doing an ORY you will need the rear o2's tuned out, that gives you an extra pair right there. |
(Post 9551926)
(Post 9551926)
(Post 9551926)
i will pplug the o2 holes up for the first heat cycle |
mine are coated inside also....no problems.....2 years now,,,,,:nod |
(Post 9551926)
forgive me, but they are ceramic COATED? Doesnt that mean the outside of the header? If so, then your O2 sensors will be fine... I wouldn't worry about the O2's. If you left the O2's out to break in the headers, the amount of gas mileage you'd lose at $4 a gallon would be able to buy you a new set of O2's :lol: |
I got a spare set of o2s for cheap if you end up needing them. |
(Post 9553457)
Hmmm, learned something, I always thought only the outsides were coated. Cool:chug: |
| All times are GMT -5. The time now is 06:02 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
