LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Trans won't kickdown & RPM's Off (https://ls1tech.com/forums/generation-iii-external-engine/960554-trans-wont-kickdown-rpms-off.html)
DTSNGIT Jul 26, 2008 10:04 PM
Recently I've noticed my 4L60E won't kickdown when you go to WOT. It will kickdown one gear from 4th to 3rd at higher speeds but not two gears as it had in the past.
I've also recently added an aftermarket tach and now notice my RPM's on the factory tach are quite high as compared to the aftermarket. At idle the factory tach reads 1000 while the aftermarket reads 600 RPM.
Both of these seem to have happened after I had the trans rebuilt. Has anyone run into these issues before? My trans guy said nothing he did would have caused these issues. Any ideas out there?
twitchtwice Jul 27, 2008 02:08 AM
idle my car car sits at 500 or a little under. do you have a cam or anything?
therealcreeper Jul 27, 2008 12:13 PM
sort of odd. it never downshifts 2 gears? if you're going over 70 it's only gonna go to third. what speed are you trying this at?
therealcreeper Jul 27, 2008 12:24 PM
you may get more responses i you post this in the transmission section
© 2026 MH Sub I, LLC dba Internet Brands
