??'s for guys running TR6's After I installed the Heads and cam on my car, the idle got just slightly rougher.. not bad enough to set a misfire code. I was running TR55's then. I swapped my original patriot 5.3's for some updated ones about a month ago, when I did the swap I changed over to some TR6's gapped at .050.. ever since then I get that nagging SES light about once a week because of misfires and my idle is alot rougher. Am I running too big a gap on the TR6's? Is the plug just too cold? Or is it something else? Thanks! |
Re: ??'s for guys running TR6's It's a pcm thing. Find someone that has a tech II and get them to do a idle learn or some people call it crank learn procedure. Basiccally It lets the pcm know what's normal as for crankshaft speed flucuations. I think that will fix your problem |
Re: ??'s for guys running TR6's You don't think I'm running to big of a gap on the TR6's at .050? I never had this problem with the TR55's. I can watch the misfires with my AutoTap and it is pretty much in all the cylinders, but only at idle or every once in a while when it is very low RPMs in 6th gear. |
Re: ??'s for guys running TR6's My TR-6's are gapped at like .038 I think .050 is too wide. |
Re: ??'s for guys running TR6's TR6s always seem to idle very slightly rougher than TR55s. I noticed the same thing when I put nitrous on my car and my roommates and swapped in the TR6s. |
Re: ??'s for guys running TR6's Ive run TR5s TR55s and am currently running TR6s. I would say your gapped to wide, you might try to reduce it to .04, and if you are spraying on a gap that big, that is your problem. |
Re: ??'s for guys running TR6's Yeah, I'm thinking my problem is the gap. I am only spraying a 50 wet shot, but the other night when I sprayed it at the track it started misfiring at WOT. It never did that before I changed the plugs. I'm going to take them from .050 back down to around .040 tonight and see if that helps. |
Re: ??'s for guys running TR6's they're .035 out of the box if i remember correctly. for anything 100+ shot i wouldnt gap them any more than .035-.040 just FYI. |
Re: ??'s for guys running TR6's Cool.. I'll do them at .040, I'll never run over the 50 shot, hell I went so far as to throw the 100 and 150 jets in the garbage so I wouldn't be tempted to use them on the stock fuel pump with my heads and cam. |
| All times are GMT -5. The time now is 10:00 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
