LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Those of you with MS4's... (https://ls1tech.com/forums/generation-iii-internal-engine/1024204-those-you-ms4s.html)
TransAm7779 Nov 25, 2008 10:26 PM
What kind of valve springs are you guys using? I ordered a head and cam package from TSP 2 weeks ago and it's coming with PRC Dual Valve Springs. Should I have them swapped out if it isn't too late?
99mongooSS Nov 25, 2008 10:28 PM
no those are perfect!
PERFECT Z28 Nov 25, 2008 10:34 PM
Thats what I have, but I've been reading that the MS4 will quickly wear out springs...
TransAm7779 Nov 25, 2008 11:14 PM
Yeah, I've done a little reading and have read pretty much the same about it wearing out the springs. Hopefully they don't wear out too soon.
Super Speed Nov 25, 2008 11:20 PM
You will probably get 20k out of them, LSK lobes = spring rape!
SS4Luck Nov 26, 2008 12:30 AM
im heads only running the PRCs should be perfect!
fatdave Nov 26, 2008 07:15 PM
Those are the springs I am running with my MS4
TransAm7779 Nov 26, 2008 08:00 PM
Cool, that makes me feel a lot better.
383vert Nov 26, 2008 08:49 PM
same here. doing well, sill, after @12,000 miles.
PI HAT Nov 29, 2008 08:30 AM
I know this is a one in a million shot of operator error, but, Im running comp 921 behive springs and have less than 1000 miles on them and broke one recently. I figured I didnt let it warm up properly. I just ordered the Patriot Gold Duel Springs.
The Comp srings were rated at .650 but the MS4 is rated at .651. The Patriot springs are rated the same but I dont have an extra 200$ for the springs rated at .660.
RAZORS10 Dec 3, 2008 07:53 PM
I have the patriot extreme springs am i safe?
Thimble Dec 3, 2008 08:30 PM
Comp 921's are dual springs, not beehives, and they cost way more than any other spring previously mentioned in this thread.
If you had beehives, they were probably 918s, and those will not tolerate a hi-lift cam like the MS4.
:cheers:
03Sssnake Dec 3, 2008 08:51 PM
:funny: sig material!
TransAm7779 Dec 3, 2008 10:12 PM
Well, the parts came in today. Everything looks great! I'm starting to think about running a forged 402 or 408 instead of my original 347 idea since I can't find an ls1 shortblock anywhere around here. Anyone daily drive a 402/408? Does anyone have experience with Scoggin Dickey's 402 rotating assembly? http://www.sdparts.com/product/LS2RA...gAssembly.aspx
smokinponcho73 Dec 4, 2008 01:45 AM
I daily drive my 408 with the ms4 and in the rare ocassion that i do drive it nice i get about 15 in town. The ms4 does surge quit a bit though and is hard to drive at certain rpms. It is a ton-o-fun though
TransAm7779 Dec 4, 2008 07:59 AM
Yeah, I read about the surging. I think I'll be able to live with it. If you dont mind me asking, how much did your machine work cost you?
Jon@Texas-Speed Dec 4, 2008 10:33 AM
If you are looking for a 347 short-block, we have several on the shelf. We also have both aluminum 402 and iron 408 motors on the shelf as well.
On the cam surging, most of that can be tuned out. At extremely low RPM's, yes there will be some. That is just the nature of big cam. However, in a 408c.i. motor, the cam should drive pretty well. I had a 257/266 in my 408 stroker and I could use my remote start and the car would fire every time and immediately find an idle w/ no surging. There is no reason a MS4 can not do the same.
Let me know if you have any questions or concerns and we'll get you fixed up right away!
Jon
TransAm7779 Dec 4, 2008 12:40 PM
I don't really have enough for a 408 right now, I'm still trying to save up some more. What is your opinion on the oil consumption and premature piston skirt-wear problem they are talking about in this thread? https://ls1tech.com/forums/generatio...rs-come-2.html Are those common issues?
Jon@Texas-Speed Dec 4, 2008 03:09 PM
With a properly machined block, you really shouldn't have a problem. I think the biggest part of his problem is the fact that it is a new motor and the rings weren't properly seated yet and there wasn't proper breathing on the motor. Piston skirts typically don't have a problem with the proper side wall clearance. If the machine shop doing the work doesn't have proper side wall clearance I could see it hurting a piston.
Jon
cjh Dec 4, 2008 06:17 PM
I have around 10,000 miles on my ms4 and still going strong, I dont daily drive mine but could if need to. Car doesn't really surge unless really low rpm like jon said. Awesome cam!
© 2026 MH Sub I, LLC dba Internet Brands
