What's the weak point in my motor? LS1 block for turbo Mahle forged pistons Eagle H beams Stock Crank LS7 lifters Hardened PRs ARP Main and head studs What is going to be the limit to how much power I can make? And how much should this be able to support? |
its good combo i think ,but just one thing....why the Ls7 lifters?? if your going to spend lots of mony go for more relible parts i wouldnt name a company you need to search but i think ls7 lifter is not relible on high boost application . i think you can go aroung 700-800 hp with no problem of course with good set of heads and lower compression . |
n/a or power add? |
Originally Posted by letsrunem
(Post 10614488)
I think the crank is fine unless he starts getting into big boost... but I do agree on the pistons. I went with Wisecos on my build. |
How are the Mahles on nitrous? Say a 250 shot? |
I too am wondering I have some of those same pistons I want to run a 200 shot |
Originally Posted by 99blancoSS
(Post 10615383)
n/a or power add?
Originally Posted by JPH
(Post 10619232)
Honestly if this is for a Turbo motor, I would have like to see you use a different piston, Diamond, JE, Wiesco, etc because of type of forging material, and upgraded crank maybe?
Originally Posted by gts500
(Post 10615375)
Originally Posted by djsanchez2
(Post 10620255)
How are the Mahles on nitrous? Say a 250 shot? So what would fail in the event of a boost spike? A meth kit will go on eventually. Say it runs out on high boost, what do I have to worry about? |
| All times are GMT -5. The time now is 07:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
