LS1 Crank fit 6.0???
Old 02-06-2009, 03:21 AM
frankmarroquin's Avatar
Default LS1 Crank fit 6.0???
I have an issue... I have a 01 or Older 6.0 LQ9 but my Crank is too long and keeping me from mount my tranny right. I have heard to just swap out the crank and walla it should work fine. But deos the crank need to be from a 6.0 or would any LS1 or Vortec fit it too? Thanks guys
Old 02-06-2009, 03:35 AM
Soul TKR's Avatar
I believe any LS1 should fit... but not 100% on that...
Old 02-06-2009, 09:56 AM
Bump for the morning....Anyone?i
Old 02-06-2009, 10:25 AM
Chris10an's Avatar
It will fit right up. of course you must measure Bering's etc
Old 02-06-2009, 10:42 AM
12secSS's Avatar
The 6.0L, 5.7L and 5.3L all use the same crankshaft, they differ only with balancing, so if you use a 5.7L crank in a 6.0L short block you will need to get the rotating assembly rebalanced. This will ensure the crankshaft counter weights are balanced to the pistons and rods correctly, otherwise you will have an inbalance issue which could ruin your engine.
Are you sure you have an LQ9? Only the 1999-2000 LQ4 had the longer crankshaft. This was for it to mate up to the 4L80E. When the LQ9 was introduced in 2001, they mated it to the 4L60E. GM switched the crankshaft to the standard Gen3 unit and used a spacer on LQ4 destined to be used with 4L80Es.
Old 02-06-2009, 06:53 PM
1FastBrick's Avatar
Fairley accurate info right there. FWIW The LS1 5.7 Cranks are gundrilled through the mains with a 1 inch hole. As siad you will have to Balance the roataing assembly and double check your clearances... All information that I have seen states LQ9 option started in 02. If you have the 1.25 inch thick rear main on your crank it is either a 99-00 model and most likely has Iron heads. 01 was the first year for the aluminum heads.
Old 02-06-2009, 08:19 PM
You know what I think it is a LQ4... Is there anyway to mate it with my 4L60e other than changing out the Crank or Swapping the tranny?
Old 02-06-2009, 08:29 PM
1FastBrick's Avatar
Not that I am aware of. Those early ones were desingned to only be used with the 4L80E hince the Longer rear crankshaft... I am Not sure what it would cost to have the rear snout turned down from 1.25 to .857
Quick Reply: LS1 Crank fit 6.0???
