Vavletrain's weak links logically, everything should be replaced for high RPM motors... but how much can everything take... What RPM will each STOCK part break: What RPM will each STOCK part will cause valve float: Whats the biggest cam before each STOCK part will break: Whats the biggest cam before each STOCK part will cause valve float: - Hydrolic Lifters - Pushrods - Rocker Arms - Springs - Retainers - Locks - Valves |
Bumppp |
If a cam goes in there Replace..... Pushrods w/ Properly measured Chromoly Springs You can reuse the retainers if you stick with Beehive springs, go to Ti if using a Dual coil spring. Lifters when you kill them, alot of that has to do with spring pressure. Stock rockers last a long while, only on high rpm set ups do I see people opt for Jesel. Valves and locks should not need replacing. It really depends on what your goal is. |
so with say PRC .660 springs, which have and open pressure of 390lbs would need new lifters due to the extra force required to open the springs? so is it better to get springs rated for .600 for a .595 lift cam, or would prc .660 be the best |
Stock valvetrain components are for the stock valvetrain (exception is the rockers). If you are going to run a bigger spring with more RPM then you need better lifters among other things. |
^naturally.. i want to know the RPM that everything is safe for/ rated for |
Originally Posted by greatskiiiier
(Post 11025737)
so with say PRC .660 springs, which have and open pressure of 390lbs would need new lifters due to the extra force required to open the springs? so is it better to get springs rated for .600 for a .595 lift cam, or would prc .660 be the best TI retainers w/ compatible locks and seats for the springs Chromemoly pr's That is the only absolute requirements. Now for the optional, recommended replacements LS7 lifters LS2 timing set ported oil pump Optional performance repalcements Yella Terra rockers |
ok... but do you need such a stout spring for say a .595 lift cam? would it have an advantage? higher RPM without valve float? last longer?.. compared to say a spring rated for .600 lift |
(Post 11031995)
ok... but do you need such a stout spring for say a .595 lift cam? would it have an advantage? higher RPM without valve float? last longer?.. compared to say a spring rated for .600 lift What cam are you thinking about running? |
If he's running a .595 cam, then a .600 is not enough spring as it's too close for comfort in case of an over-rev. |
ya that what i figured... im kinda looking at PRC 2.5 5.3s an they come with .660 springs.. and im looking to go with roughly a 228 .590 cam but figured id see if its worth replacing anything now while i try and save up funds |
(Post 11034424)
Originally Posted by Viper
(Post 11033487)
its all cost/ HP ratio... yes ive looked at 228R, VRX3/4, some TR stuff...... |
(Post 11033487)
(Post 11033487)
If he's running a .595 cam, then a .600 is not enough spring as it's too close for comfort in case of an over-rev. Anybody who changes out springs should use an installed height micrometer to verify the setup. I suppose if you do a true drop in (stock everything on the valve side; valves, locks, retainers, seats) then you can probably get away with not checking them if you know the factory specs. If you want to learn more, please take the time to read this: CransCams on Valve Springs Ken |
| All times are GMT -5. The time now is 02:55 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
