is there a way you can pull the pulley off of the waterpump? im fixing to powdercoat all my pulleys and waterpump,is there a way to pull that pulley?its a 2002 ls1.and the engine is on the stand. |
bump please help |
i removed the pump and taped the pulley off real good and painted mine. i sprayed a lil behind the pulley and cant see where the paint ends or any unpainted areas |
I'd be worried about the seals in the water pump surviving the baking. Re' |
i thought the older water pumps had the pulley bolt on IIRC |
the pulley would have to be pressed on and off, there is no other way to do it. |
So powder coating the W/p will mess up the seals? |
I was told by various powdercoaters that it possibly could mess up the seals....just depends on what temp they use to bake it. |
Originally Posted by xpndbl3
(Post 11134920)
4 Attachment(s) I got the same problem.. I have my timing cover and valve covers power coated black hammertone... I wanted to do the water pump but I dont even want to risk it usually the temps that are used to melt the coating is between 300-500 degrees.. the pully needs to be pressed on and off.. But I just decited to rattle can the pump black.. I think it should look fine.. But here are some before and after pics.. sorry but they are tiny |
© 2024 MH Sub I, LLC dba Internet Brands
