Id'ing a LQ4 vs an LQ9
Old 03-16-2009, 09:58 AM
Boosted One's Avatar
Default Id'ing a LQ4 vs an LQ9
I bought an engine out of a junkyard for my turbo build. It is out of an 07 Van. It's a 6.0, but how do I tell if it's an lq4 or lq9 without pulling a head to check the pistons.
Thanks,
Frank
Old 03-16-2009, 10:05 AM
Sid447's Avatar
They only fitted LQ9's,
to Cadillac Escallades and GMC Denalis AFAIK.
Old 03-16-2009, 10:07 AM
Great! Thanks for the quick reply! That's what I was thinking, but I wasn't positive.
Frank
Old 03-16-2009, 10:09 AM
Sid447's Avatar
Your only a set of pistons away from an LQ9 spec anyway,
They were identical other than that I think (apart from small differences in the tune).
Old 03-16-2009, 09:41 PM
dre2013's Avatar
correct, vans only had the lq4
Old 03-16-2009, 10:39 PM
elias_799's Avatar
if you are going FI, you want the lq4 instead of the lq9 because of the lower CR. and it seems to me that you have an lq4.
good luck on you build.
Old 05-01-2009, 10:52 AM
turbomanlq4's Avatar
Here is an answer to your question one person was right one is aluminum and the other has a cast iron block the one you have has the cast iron block which is better for turbocharging.
Old 05-01-2009, 11:15 AM
adam1803's Avatar
negative, no LQ4 or LQ9 was ever built with an aluminum block. The only difference is dished pistons on the LQ4 and the LQ9 i believe has slightly beefier rods. FYI, the LQ9 was also put in the Silverado SS.
Back to the OP though, you definetly have an LQ4 if its from a van.
Old 05-01-2009, 11:53 AM
12secSS's Avatar
As adam1803 said, but to add you are thinking of the LS2.
LQ4/LQ9 = Iron Blocks
LS2 = Aluminum Block
All three are 6.0L, and the LQ9 is an iron version of the LS2 but with 317 heads, versus the LS2 and the 243 heads.
Old 05-01-2009, 01:47 PM
GMCtrk's Avatar
later (2005) and up lq4's have the same internals as the LQ9 and LS2 sans the pistons. The LS2 internals are identical to the 02 up LQ9's I believe.
Old 07-10-2009, 03:32 AM
Ford_Assassin's Avatar
So if you don't know what the motor came out of, how else can you tell the difference between a LQ4 and LQ9?
I have a 6.0 long block, and I know its an '05 model year because of the casting date on the heads (10/04).
So how else I can I tell without yanking a head to look at the pistons?
Thanks!!!
Old 07-10-2009, 03:42 AM
Sid447's Avatar
Smile
So how else I can I tell? Thanks!!!
Have a read here:-
http://en.wikipedia.org/wiki/GM_Vortec_engine
LQ4 has dished pistons, LQ9 has flat-top.
Old 07-10-2009, 03:51 AM
Question
Have a read here:-
Thanks dude, but I guess I should of been more specific.....
I don't want to yank off the heads to confirm if it has flat top or dished pistons on a perfectly good long block..
Any other way to tell the difference without tearing into the motor?
Thanks again.
Old 07-10-2009, 07:16 AM
Tough Mudder
Hilton's Avatar
Is it possible to pull out a plug and use a screw driver or something similar to feel the top of a piston? Maybe a wooden dowel rod?
Old 07-10-2009, 07:22 AM
deadhorse66's Avatar
Other than what these guys have already said, there is no way to tell them apart. Pistons are the only difference.
Old 07-10-2009, 09:24 AM
5.3LJimmy's Avatar
I remember seeing a thread on performancetrucks.net that showed how to identify the pistons from the bottom. It had pictures detailing the differences between the two. It wouldn't be a big deal to pull the oil pan and have a look.
Old 07-10-2009, 10:05 AM
If that were true it would be great since I am swapping out the truck pan for a LS2 Corvette pan anyway.
Old 07-22-2009, 06:50 PM
dwfronk's Avatar
compression test. Find out the stock compression for the lq4 and lq9 and check compression. assuming you have the heads on the block that came on it.
Old 07-22-2009, 10:36 PM
5.3LJimmy's Avatar
Man, that only took about an hour of searching. It appears that the question "What's the difference between LQ4/LQ9?" is as popular on PT.net as "What cam should I get?" on here.
http://www.performancetrucks.net/for...ght=LQ9+piston
If you look at the pictures in this link you can see the obvious difference between the LQ4 and LQ9 pistons. I would say it's no problem to identify them this way from the bottom.
Old 07-23-2009, 04:01 PM
snksknr's Avatar
Don't mean to hijack this thread but what is the stock compression ratio on the lq4? thanks
Quick Reply: Id'ing a LQ4 vs an LQ9
