Guys with 383's
This is my situation sooon for a LS1 with 100,000kms on it.
4" Eagle 4030 crankshaft
Scat H beam conrods
Clevllite race series bearings
Forged pistons & rings
Balanced
Modified oil pump & oil system
228 232 camshaft
JP double row timing chain
Trick Flow Heads 220cc
Double valve springs
Comp 850 lifters
Moly Pushrods
Yella terra Rockers
25% UDP
FAST 90mm Manifold
Nick Williams TB
ARP head bolts
Cometic head gaskets
New Clutch to suit, salve, spigots
Have already 1/34 pacemaker 4in1s, 2.5 exhaust OTRCAI maffless, 3.9 gears
Can anyone advise another cam for me
My ute is weekend driven so lookin for lumpy but heard much good stuff from 224 228 and 228 228 cams as lower power in rev range yet still running good times and driveablity
even a 232 234 stick
cheers mick
Scat H beam conrods
Balanced
228 232 camshaft
Comp 850 lifters
Moly Pushrods
Yella terra Rockers
25% UDP
FAST 90mm Manifold
Nick Williams TB
ARP head bolts
cheers mick
