LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Harland Sharp RR on 243's... Clearance Issues? (https://ls1tech.com/forums/generation-iii-internal-engine/1113556-harland-sharp-rr-243s-clearance-issues.html)
SLCKLS1 May 7, 2009 04:53 PM
Hey all, I am going to be running some Harland Sharp Roller Rockers in 1.7:1 ratio and I am wondering if any of you have had any issues with both valve cover clearance (do I need spacers?) and head wall clearance (The 853's I test fit them on needed a bit of clearancing)
Im more worried about the valve cover clearance. Anybody having any issues?
Thanks!
SLCKLS1 May 8, 2009 07:49 PM
Anyone?
Who is running aftermarket rockers, which ones are you running and do you need valve cover spacers? If so, what lift is on the cam?
Tee1up May 8, 2009 08:51 PM
harland sharp
Im running these rockers on my 403 and had to grind a little on valve cover
due to some interference and that solved the problem
cam has 640/644 lift
© 2026 MH Sub I, LLC dba Internet Brands
