Anyone tried PRC 237CC full aftermarket casting heads?
LS1Tech Premium Sponsor
I'd be very interested in knowing the rest of the story ^^! We've tested them on the engine dyno with virtually every camshaft combo we could find, back to back with all of our other heads and numerous competitor's heads as well....Not once did they ever lose HP or TQ like you state there vs the 5.3L heads (or LS6 for that matter)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
PRC 237 for sale
hi..i have a prc 237 heads set to sell ..the price is 1800$ and comes with the 7.550 pushrods..anyone is interested .better price you will found everywhere..they are ready to go..
PRC 237 made 512rwhp@5800RPM and 487 RWTQ on my LY6 iron 427..and PRC stage 2.5 make 525RWHP@5800RPM and 506RWTQ..all at the same AFR ratio of 13.1AFR..came back with 5.3 stage 2.5 heads and 525RWHP AND 506RWTQ ..i think that i may have valve-flotting condition with these rollers rockers but i changed my .650spring and replace it by 675eht double and i have corrected the 6400rpm valve flotting that i had..but can i already have the same problem at 5800peak with no valve flotting until 7000rpm with eht .675 springs kit..?
C5 427 LY6 IRON PRC HEADS , FAST 102 WITH BIG MOUTH NICK WILLIAM,ARHEADERS,X-PIPE,BORLA CAT, CAM 238-240 AND .655-.650 WITH ROLLER 1.82 110LSA,EHT DOUBLE,
.675 SPRINGS KIT,
.675 SPRINGS KIT,
We have a set of the 237s right now going on a 408 and they look very nice and should have some dyno numbers within a month probably as I think Pat G is tuning this one.
interested in the 408 results i wanna see what these heads bring to the table, also with numbers post up the camshaft specs,and springs used,lifters, ect ?
thanks,
those LQ9s are a good cheap block to work with only 100 lbs heavier but they are good,,,,,
thanks,
#35
Seems like to me the 5.3 heads would bump the compression up vs the 237's which would lower it and explain his loss. Now for the boosted guys such as myself, we don't necessarily lose anything since we force alot more air through them. So where as they may lose you 10-15hp (allegedly) on a N/A setup. Curious what chamber size he was running.
#37
.675 SPRINGS KIT,
.675 SPRINGS KIT,
" driver240 " at what chamber size did you run those heads at ? did you have them milled ?...
#38
483rwhp PRC 237 Heads , TSP Nitrous custom cam , Full Boltons and TSP Built 6.0 LS2 for nitrous This was on 91 octane and 90+f weather
The car screams all the way past 7200rpm
https://www.youtube.com/watch?v=2pYszdvKD6o
#39
I am still working on it Eric, I put the motor in this weekend and will try to get the tranny back in next weekend, After that I will be getting back in touch with Pat G to set up a time to take it to Victoria. It's hard to find time to work on the car with my work schedule but it is coming along, I am making sure I do everything right, the car hasn't ran in 12 years so no need to rush it now. Erik I will send you the results when I am all done, i haven't forgot about ya. I'm sure I'll be posting them here also....The title will say " HKE + Pat G = ____rwhp for Me"
#40
