New Era Street Sweeper High Torque Camshaft
I was cosidering using this camshaft in my car and was wondering if anyone has any info on it. good or bad. the specs seem like it is a pretty well rounded cam. you cam experts out there help me out. thanks.
Specs Int Exh
Duration @ .050 228 232
Lift .612 .600
LSA : 111
Specs Int Exh
Lift .612 .600
LSA : 111
yea aint that the truth. well i plan on changing the heads over time. but i was just curious to how the cam was across the rpm range. i have thought of puttin a bigger cam like the one you have but i dont think it would fit my needs. considering that my car is a street car i just wanted the cam to kick in way before 3000-3500 rpms. basically want the cam to kick in out of the gate from a dead stop and not stop pullin.
Well bigger cams want more air/fuel and the same for expulsion, ie; more flow, so supporting mods need to be in the works to get the most out of the cam. If your on a budget like most of us, I'd start with better intake, if your is stock. Like I said better valve springs/pushrods are going to be a must, and maybe port your heads or shop the classified section here, I see alot of LS6 intakes/heads..going pretty reasonable..
Id for sure do valve springs, and while you have the heads off use some thinner gaskets to bump the compression to around 11:1 and im sure with your current mods you will be happy with the power, and later when you add better heads they will come with upgraded valves anyway.
I daily drive my car and wanted a cam that sounds awesome and gained power everywhere. My cam is smaller than the cam you listed, but you can see that I gained power everywhere. I dynoed the car starting around 2000 rpm when it was mostly stock so you can see I didn't lose low end power at all. I shift around 1500 rpm and can lug down around 1000 rpm no problem. I've pulled it to 6700 rpm and the power doesn't drop off. My setup was done with a tight budget but I am very happy so far.
Here is what I did: https://ls1tech.com/forums/dynamomet...80hp-53tq.html
