LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   TSP 231/237, QTP LT's installed (https://ls1tech.com/forums/generation-iii-internal-engine/112532-tsp-231-237-qtp-lts-installed.html)
Heavy Metal Nov 6, 2003 07:35 PM
Well, I have been installing a Cam(TSP231/237), 918's, and the 1.75" QTP long tubes. I finished it up this afternoon. She fired right up on like the second crank...and idled at about 850 RPM :) . I have not gotten my exhaust built yet so it was real loud, I just wanted to check for leaks and go get some gas. I took it easy, proabobly drove for a total of like 4 miles. When I got back to the house it decided not to idle any more, I'm not really sure why. It runs good though, I think I just need to drive it somemore so it can learn. One mistake I may have made was opting to go without the o2 sims because I am planning on having them deleted with tuning. I wont be doing that until I get it quieted down a bit. I must say, the install work was pretty easy, I used a cut-down lever type tool for the springs, and the JPR cam tool. Anyways, I just wanted to share and thanks for all of the help I got from everyone on this board. I'll try to post some pics and stuff later on.
Aaron
:chug:
Damian Nov 6, 2003 07:37 PM
Check your plugs. Driving with open headers is an easy way to foul out plugs and could possibly be your idle problem.
Congrats on the setup, that cam makes great power with a dyno tune.
Josh
Heavy Metal Nov 6, 2003 07:49 PM
Josh
Thanks, I'll check that out, I dont like driving it with open headers. Now that I know it runs, I'll just park it until I get the exhaust done this weekend.
Aaron
Classic Nov 6, 2003 08:07 PM
Congrats! I had that cam with some mild LS6 heads and it made great power. You will really like it.
The other part of your idle problem could be your TB. Did you drill it out at all to get your IAC values down?
© 2026 MH Sub I, LLC dba Internet Brands
