which valve springs i just ordered MTI C1 and now which valve springs should i go with? :hail: is it a must to have tit. retainers?? |
Comp 918's are popular. I'm also running Comp ti retainers. |
Go with the crane dual spring. |
im running a cam with C2 specs and will be running crane duals (as soon as they show up at my door) |
has anyone ever used scoggin dickeysvalve spring kit ? if so what do yall think about it? would that be good for my set up?? http://www.sdpc2000.com/cart.asp?act...art&catid=2270 |
is anyone running the manley springs if so which ones? |
I used Comp 918's when I had that cam. Tit Rets. would be nice, but not necessary. Do get hardened pushrods though. |
Originally Posted by Red01Chevy has anyone ever used scoggin dickeysvalve spring kit ? if so what do yall think about it? would that be good for my set up?? http://www.sdpc2000.com/cart.asp?act...art&catid=2270 |
is it a must to have hardened pushrods? |
It's not a must, but it's strongly recommended. When you compare the two next to each other you'll see why. |
are the crane duals the drop in springs? Are there any other dual springs that are stronger that are drop in? |
Comp now has drop in dual springs. |
I am going with 918 springs and Thunder Racing hardened pushrods for my cam swap. |
Comp 921's. Drop in's. Might look into these once my 918 have enough miles, or shall I say qtr mi passes on them... |
I'm using 918's and the "772" Ti retainers with a C1. 10K on the springs and so far, so good. I also am using the hardened pushrods. |
The Crane duals are a drop in spring, no machining. I'd say no matter what, go with a dual spring and stay away from the singles. There's another post befoer this one where a guy used those Comp 918's and the spring broke, wreaking havoc in the engine. With a dual spring you're almost always gonna have one spring to keep the valve up and save the motor from serious damage if you have a spring break. Plus, the duals have better harmonics for sustained RPM's and longevity. |
what are the prices and part numbers on the comp and crane dual springs?? can i use my stock retainers and locks? |
There will be a couple of new valve springs introduced for the LS1/LS6 applications at the PRI show in December. A drop-in 1.260" made from ultra clean chrome silicon. Also a 1.480" spring for the high lift stuff. These engines will also benefit from the restrictor pushrod which helps in maintaining proper valve pressure in the lifter and promotes higher rpm. Cstraub |
for a MTI C1 cam which pushrods should i get what length?? |
Match the stock length. |
© 2024 MH Sub I, LLC dba Internet Brands
