will not idle after cam install just finished my cam install and we cant get it to idle, off idle runs like a champ. the engine was totally rebuild so trailing it to get it dyno tuned is not an option because i need to break the motor in. the cam is a tr230/224 w/40bph injectors we do have hp turner so we can play w/the tune. any ideas? |
Get a decent drivability tune. Make sure you have the car tuned for the injectors. |
well we got a tune from hp tunes website, for a heads cam car w/38bph injector, but it still was not right. it would not idle and it was running very rich. |
I dyno tuned my new engine with less than 200 miles on it stuffing 10 #'s of boost down its throat. Keep the engine alive and give it some some heat cycles and some WOT bursts and go get it tuned. |
See if you can shorten the injector pulse at idle. Sounds like your dumping too much fuel into it. |
messed w/the tune this morning, idles around 850 and sound great. |
Originally Posted by 02b4ccamaro
(Post 11966020)
the engine was totally rebuild so trailing it to get it dyno tuned is not an option because i need to break the motor in. |
Mine had a lot of trouble starting / idling after the cam went in, mostly the low end of the VE table needed cleaned up. It was way overfueled until I got that part straight. The cold EQ vs ECT and afterstart enrichment were also way more than it wanted. Gas, gas, gas. |
Reset your idle. We just did the same cam in my car, but with a 7.25" clultch and button flywheel (-30lbs from stock). It would idle, then surge itself into a stall. The tuner went in and upped the idle RPM to about 1000 or so. It got rid of the surging. Of course, this was just a fix until we got it on the dyno and could fine-tune things. But, it let me drive from Point A to Point B, and move the car around. |
we are going to mess w/it a little more to today, but i drove it home last nite about 6miles and it was fine. i just have to put it in netrual then i stop at a red light |
© 2024 MH Sub I, LLC dba Internet Brands
