How to flycut pistons in an LS1 for free! (almost)
#81
You only need to cut as much as you safely need to clear. You could go back to stock rockers with that cam, and gain a little bit clearance wise. I like the gasket choice for quinch however. Lots of guys here, including myself have done this, and it’s really simple. Did you use clay to check for this? Seems odd that a 227/.600” camshaft would hit pistons, but stranger things have happened.
I did use the clay method and my intake valve is squishing through and ever so slightly leaving a wear mark. Maybe there's something wrong with my PTV method? I'm using my old ls1 lifters with the components flipped around to make a solid lifter should I be doing this?
#82
Thank you for responding!
#83
#84
you need more than "just enough to clear." i forget what the recommended PTV for the intake and exhaust valves, but i think it's around .080-.100. if it barely clears turning by hand, doesn't mean it will at 7000 rpm at operating temperature.
and duration matters way more than lift in terms of clearance. interference doesn't happen anywhere near max lift. rockers only slightly affect duration, so their effect on PTV will be minimal. if you want more PTV without flycutting, you need a different cam or heads with more valve drop.
