Have 1k to spend on performance mods - suggestions!
Hello all,
I am going to be picking up my new 02' Camaro Z28 with 36,xxx on the clock. It has a magnaflow exhaust and I'm looking for low 13s high 12s. I was thinking of drag radials, tune, and a K&N intake. Or should I go with headers instead? Or just a cam if the stock manifolds flow good? Let me know!
Tom
Tom
Is your car an automatic or manual?
If automatic, get an aftermarket torque converter ASAP!
Pacesetter long tube headers are cheap and easy to install.... Don't get a cam until you get all the other bolt-ons...
Formerly darynC-10/23/10
headers are a must and a air lid..
if ur on a budget some painted pacesetters are aroond 400
and ceramic coated ones are in the 500-550 area
if your not on a budget then i would look into some kooks or american racing they make good stuff
also ive had y pipes utilizing the flowmaster merge and a electric cutout and i was very happy with it
as for the air lid ... anyone but STOCK will do just fine!
you can also look into getting an underdrive pulley... some dyno tests have proven 5-10 hp/tq increase
as for the basic bolt ons thats about it , u can get a dyno tune
Also, the last time I did headers on a car it was off the road for almost two months because nothing bolted up. What headers will bolt right up to my magnaflow exhaust? I want something that I can easily do in an evening - no hacking, welding, grinding... And then take the thing to work the next day!
Thanks for all your suggestions guys.
yes the stock intake uses an air lid but it has a baffle between it and the intake manifold. which loses power big time!..... an after market lid does away with the baffle and thus gains you a few hp , and cleans up the engine bay a helluva lot!
pro products sells a good ud pulley, so does summit.
headers are not exactly a bolt in deal, u will need matching y pipe and necessary mods to splice into your exhaust. weld,cut,etc.
will also need tune for new headers, esp. if deleting cats.
imo a lid with filter, a cutout spliced in your exhaust, msd wires, smooth bellows, udp, and a tune will really wake your car up.these are low price mods and work. and upgrade your lca's. and if possible some sub frame connectors.
GO with a cam and new springs look for a kit there cheaper. maybe 499. Dont worry about the rocker run the stock ones. Look for a good set of long tube headers, Maybe used or skip the headers for now and get sub frame connectors. If your going to be beating on the car alot
i can help you out with some used parts to save you some dough if your interested. i've got hooker headers (ceramic coated) and a really nice aftermarket lid i can get you a good deal on. Also have a cam, springs, and pushrods but i dont know any of the specs becuase the cam was a custom grind. pm me if you want to work a deal on all the stuff i got!
Are you going to do the work on the car or have the parts installed by someone? A thousand dollars can go away very fast. You can get headers, ory, lid and dyno tune will wake the car up. Smooth bellows are really a waste of money as they are mostly for looks. A pulley again imo is not worth the gains for the money (around 200 with belts) for 7hp? A cam kit (cam,springs,pushrods) will run at least 600 new plus a timing chain. And of course if you are not putting all the stuff in yourself there goes more of your spending money.
6 speed - FTW!
Cams are around $355 How much can valve springs and accessories for that install going to run me? What about roller rockers?
<snip>
<snip>
For great fitting headers, you need ARH or Kooks. Truly bolt-in stainless steel great products, but also outside your stated budget.
I recommend you finish your boltons, lid, exhaust, etc before getting a cam.
Good luck!
I just spent about $1100 for my cam parts, including ported oil pump, cam, springs, LS2 chain, gasket set, new crank bolt, new plugs, misc other stuff/tools. You can skimp on some of that stuff, but you shouldn't.
Good luck!
Good luck!
i agree with the new chain and pump. but since his car as low miles.. its not necessary ...
I just did a cam install and it cost me 1600, not including install.
Don't do a cam. If you do a cam right, it'll cost you a lot in the long run.
cam-350
oil pump-100
pushrods-135
springs and retainers-500
Timing chain-150
Gaskets and crank bolt-100
new plugs-15
oil and antifreeze-50
tune-250/500
Yes, you can buy all this cheaper, but if you're doing it, might as well do it right the first time.
Doing a cam without supporting mods is just...silly
Just go with headers/ypipe, lid, free mods, and if you have some left, tune
cam-350
oil pump-100
pushrods-135
Timing chain-150
new plugs-15
tune-250/500
cam-350
oil pump-100
pushrods-135
Timing chain-150
new plugs-15
tune-250/500
cam-350
oil pump-100
pushrods-135
Timing chain-150
new plugs-15
tune-250/500
and the results were
Hello all,
Tom
Tom
right on Mad Ice. also, makes no sense to do a cam swap without the supporting mods. get some used longtube headers, air lid, pulley, and some good tires. and maybe use the rest towards a bit of suspension like subframes and LCA and stuff. you should be able to probably get all those parts in the used section and u might have a few hundred left over to save for your next mod like a cam, converter, or a 12 bolt.
