milled heads, still cam only or no?
I don't know that there is a specific rule list or anything for what is considered "cam only" on this board. Typically it is viewed as bolton's and a cam swap only. However, if everything else in the heads were stock, I wouldn't think milling would count against you. However, there are some sanctioned classes that state that any modification to the heads is prohibited. It just depends what you are shooting for. Hope that helps.
Jon
Jon
well a buddy of mine was arguing with me about it and he said cam only is stock, untouched heads. well the guy that did my motor said since i still had stock heads and not ported, i was cam only. so i wasnt sure. i guess there are may sides to it.
