headgasket with 243's on a SBE
Will be throwing on a set of 243 heads onto my SBE ls1...what bore headgasket should I run? I would like to go with a GM mls gasket if possible, and was looking at these 12589226...will those work? any help would be great...thanks.
thanks for the response...its a stock bottom end ls1...im pretty sure they are ls6 243 heads so I want to run a GM stock thickness MLS gasket...anyone think that would be ok?? and mike SBE means stock bottom end...
