oil pressure on my built 6.0
all right this is a stock lq9 with arp rod bolts and flycut pistons. It has a ls2 oil pump and timing chain. it has ported and milled to 59 cc 862 heads with 2.02 1.6s valves. right around 12:1 on e85. anyways it takes a good 5-8 seconds for the oil pressure gauge to even start movin and goes to like 25 psi or so. should i be worried about it building pressure so slow?
If it shows low on the mechanical gauge, id have to bet the oring. Everyone is "careful" with it. But it doesnt leave much else if you havent had the rotating assembly appart.
