Day 1 of 224/228 cam, 96mm TB, heads, 92mm FAST swap
#42
LSX Mechanic
Do you even know what point your trying to make? Or which one of mine you were trying to debate?
I never said his car would be slow. I was speaking in terms of dyno #'s only. Also, if you'd read the thread in it's entirety, you would have seen my latest reply telling the OP not to worry about the dyno #'s because his track results were great.
Run along now...
Run along now...
#44
Weight is what is killing me. I am still trying to get the graph from Fran and will post it so the picture is clear. I think it did real well and know the air sucked! We are putting stock rockers back on this weekend and I will hit it again next Saturday on test and tune when they prep the track better. It might have an 11.1@120 in it.
#48
It almost seems like the pedal might have been lifted just for a split second....I mean it only drops for 200 rpm or so, it would be nice if there were more then one run.....can you get any more graphs or is this the only run that was made?
#49
Well I did a search and found a post similar. At the bottom is a link to another post where they saw a similar problem:
https://ls1tech.com/forums/dynamomet...lve-float.html
#50
#55
Well we switched to the stock 1.7's today and the car started hitting the rev-limiter like butter.
It's making power past 6200 now. I think it does have an 11.20 over 120 MPH now in it.
Very weird it never hit the rev-limiter on the 11.46 pass. Today it was hitting it good so something has changed.
