LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   PP Stage 3 LS6 heads...who's got em... (https://ls1tech.com/forums/generation-iii-internal-engine/119768-pp-stage-3-ls6-heads-whos-got-em.html)
slyws6 Dec 7, 2003 10:37 PM
Would you recommend them on my setup, I plan to try them out.
-Sly
gomer Dec 7, 2003 10:40 PM
I don't think they'd be worth very much over the stage II's on a stock cubic inch motor. But heck, every little bit is worth it.
btw.. have you dyno'd your current 5.3 heads and 230/236 cam combo yet?
slyws6 Dec 7, 2003 10:46 PM
Haven't dyno'd yet unfortunately, price isn't of concern tho that's why I ask. I've heard some say they will be too much for a 346, umm they flow just a little more than the Stage II's, I don't see how that will hurt. I am set up for higher RPM's anyway, 4000 stall etc..
-Sly
O2bqwik Dec 7, 2003 10:57 PM
i was told that the ls6 heads perform better in the midrange than the 5.3's did i just pay an extra $500 for nothin?
Beast96Z Dec 7, 2003 11:08 PM
Once again, I think I'm the only one. :)
O2bqwik Dec 7, 2003 11:10 PM
nevermind sorry i got the stg2 not stg3
2001CamaroGuy Dec 7, 2003 11:15 PM
Well I personally can't give a "comparison" of stage 3 over stage 1 or 2 but I can say......
I have a set of "stage 3" (2.08/1.60 valves) that were done by a local guy (he got ~300CFM @ 0.600" lift through an LS1 intake....) on my stock 346 bottom end (daily driver) and I REALLY like the performance they give.
They are BIG for the little TR224/224 I'm running (didn’t have P-to-V clearance for any more cam) but they still make the motor scream up top (I got an honest 400RWHP in 105 degree heat). I can't wait to rebuild the bottom end (forged pistons with valve notches) so I can put something like a G5X2 or 3 in it. :)
SPANKY LS1 Dec 8, 2003 06:20 AM
Originally Posted by slyws6
they flow just a little more than the Stage II's, I don't see how that will hurt. -Sly
Keep in mind that part of the reason they flow more is because they were flowed with a 4" bore instead of a 3.900 bore. That will boost flow numbers some. The added flow may not be seen on a stock bore motor.....
Silvr98z28 Dec 8, 2003 07:41 AM
Very true. Also heard you are getting what you pay for there.
Gremlin5.3 Dec 8, 2003 10:56 AM
So if someone were building a 408c.i. motor, would you guys recommend the PP LS6 stage 3 over the stage 2?
TVWilkes Dec 8, 2003 11:31 AM
On a 408c.i. motor,Iwould recommend the stage 3 vs. the stage 2.
© 2026 MH Sub I, LLC dba Internet Brands
