lets talk...mid lift airflow?
Old Nov 8, 2009 | 01:52 PM
ls2 bait's Avatar
Default lets talk...mid lift airflow?
what doe sit do? more or less.....power under the curve? peak numbers? etc. i was told if i sent my tfs 215 heads out and had them done up to 225 specs for my 416 they would gain a good amount of mid lift airflow. im trying to decide if its worth it since when im actually racing it im nowhere near under the curve...its all in the upper rpms.
Old Nov 8, 2009 | 06:33 PM
SOMbitch's Avatar
Dude I love your setup...SWEET... Call Tooley or TFS or both... They know those heads better than anyone. On a motor like yours I would think you would definitely pick up with bigger valves and runners......
Old Nov 8, 2009 | 07:30 PM
ls2 bait's Avatar
i think it will just be bigger valves and opening the chambers. from what i have gathered the 215's measure at 219-220 on the runner and the 225's measure at 224. so i would prob leave those be.
Old Nov 9, 2009 | 08:05 AM
98Z28CobraKiller's Avatar
Restricted User
The easiest way to explain it is, you have 3 guys standing in line passing a joint back and forth. The guy in the middle hits it both ways so who get's the most stoned? That's why mid lift is so important. This is also why you want to spec a cam that has slightly more lift than the heads peak at so that you pass peak on the way up and down instead of just kissing it at the top.
Old Nov 9, 2009 | 11:16 AM
mwatson185's Avatar
Ok that's pretty funny. The shape of your power curve has more to do with your cam than your heads. Going with larger heads would only amplify the current shape of your power curve.
Old Nov 9, 2009 | 11:23 AM
ssdeuce74's Avatar
older sbc's set up for drag love 230 runner heads and there not as efficent of a motor design opening those ports up over 230 would be a noticable change as long as you don't loose to much velocity the air has to still move fast for good response
Old Nov 9, 2009 | 10:04 PM
Restricted User
Having the heads worked and going with a larger head are 2 different things. There is some bowl and combustion chamber work that can be done by hand that the cnc machine wont do in order to improve flow without sacrificing velocity which is what usually happens if you just open up the runners or stuff bigger valves in.
Old Nov 9, 2009 | 10:18 PM
02*C5's Avatar
Defining low/mid/ high lift might need some discussing......
I have heard some say that due to a zillion different ports and cams available that..... one could think of low lift area as being the lift from where the intake valve actually opens to TDC......That figure could be as small as
.say .020 lift at TDC on small economy cams to .300 + on giant cams....
Others may have a different idea of what each lift area might be defined as.....
Do you guys have any thoughts of defining these different lift areas ?
