243's I did a search but couldn't find any dyno #'s that people posted. I am looking for cam, 243, A4 dyno #'s. I have a set of 243's, fuddle 3600, and looking for a good cam option. |
I have ported 243's with a CompCam 224/230 114LSA, VigStall3000, and put down 391 with the verter unlocked. |
who did the port work? |
Could not find my dyno sheet but with an Ed Curtis Cam and ported & cnc'd 243s from Advanced flow induction am at 450rwhp 422 tq through an RPM stage IV 4L60E w/ a viggi 3400 stall. I have a full set up if you want the laundry list ill give it to you. |
what cam are you using? |
Texas Speed did my heads. The dyno #'s aren't anyting to brag about, but this combo did 11.2's. |
Converter cars typically aren't dyno queens. They don't show a big number do to drivetrain loss. You can lock the converter to show a more accurate number compared to a six-speed car if you are looking for a number. However, stalled A4 car will usually out run a more powerful M6 car at the track. That's where the converter car really shines. If you would like us to port your heads just let us know. We can get you setup on either a Stg.1 head that will have fully CNC'd intake and exhaust ports and CNC valvejob with new stock valves. We also have a Stg. 2.5 LS6 that will have the CNC porting and CNC valvejob along with a 2.02/1.57 stainless valve combo. The Stg.1 will start at $650 and the Stg. 2.5 heads will run you $850. We also have a full line of valvesprings to meet your cam choice. We can also get you fixed up with a cam to match your combo and get you to the performance goals you are looking for out of your car. We have a wide variety of shelf cams and we can always do a custom grind if you would like! Let me know if we can help! Jon |
my dyno #s made me want to cry, but the car runs great and while most people are shifting im still flying! i was happy with my TSP heads. get the best springs your budget allows just in case you want a bigger cam down the road. i beat a viper that missed a shift! |
Originally Posted by TMZPERF
(Post 12487222)
Hey Jon, The 2.5 LS6 heads I got from you had 2.04's, are they discontinued now? |
I agree with Jon's points on auto's not being dyno queens and outperforming M6's which have more rwhp. IMO, the A4's that dyno high (on order of M6's with similar mods) point to dyno tinkering, miscalibration or the like. |
We went back to the 2.02. We found some more air out of the smaller valve without loosing anymore PTV with the 2.04. Jon |
| All times are GMT -5. The time now is 09:56 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
