It's time for cam selection Ok its time for cam selection this is what i have to work with: FAST 92/92 ported AFR 205's 100mm TSP mass air slp lid stock bottem end 1" 7/8 TSP headers TSP true duals With the current mods what would be the best cam? I was considering a ms4 but i am open to all options. I am going for a max effort setup here. Also if anyone can give a educated guess as to what kind of wheel power i would be making through a m6. |
since your considering the MS4 i'm guessing this is only a weekend warrior???? |
224/228 114LSA cam works great with those heads |
PM Patrick G, he can spec you one just for your application. Or even Tony Mamo since you have a set of AFR's. |
Almost any 4* split with those heads is optimal.... |
| All times are GMT -5. The time now is 05:59 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
