Best junkyard heads? I need a shopping list!!
Ok so here is the deal: I found a local junkyard with around 40 or 45 LS/LQ engines (at least 20 are 5.3s), and for pretty cheap. I want to know what heads would be the best to replace my stock 98 heads when I put my MS3 in. I plan on getting several sets to "tinker" with since the prices are pretty good. What would be the best UNPORTED heads to look for? Can someone make a list of heads and cast numbers to look for in order of best flowing to worst? ANY help is appreciated! THANKS!
You can probably look for in the neighborhood of 15 horsepower over a stock LS1 casting. Look at the left bank, front top of the head just below the valve cover rail, and you will see a 3 or 4 digit code on any LS based engine. A little fyi, the 799s are probably more rare than even a 243 nowadays, as they only came on 5.3 L33 engines which is the aluminum block Gen III high output. 243s are used on a LOT of newer (07-up) truck 5.3s. While they dont have the sodium filled/hollow stem valves, they have the same port design they've always had.
