View Poll Results: which set of Head for a mild cam'ed 346
PRC 215 $2149.99
8
7.92%
AFR 205 $2285.99
36
35.64%
ETP 215 $2399.99
8
7.92%
TFS 215 $2399.99
49
48.51%
Voters: 101. You may not vote on this poll
PRC 215, AFR 205, ETP 215, or TFS 215
Polling your thoughts on a set of heads. Not to beat a dead horse but I'm in the market for a set of heads. These are all around the same price (from TSP)
#1 PCR 215 $2149.99
#2 AFR 205 $2285.99
#3 ETP 215 $2399.99
#4 TFS 215 $2399.99
The car these will be going on is an 01' A4 Z28 LS1 346 with your basic bolt on's like SLP lid, cat-back, LT's w/ory, gear, stall, OH! and a cam.
The cam is: .598int/.600exh and 226*int/230*ext with a 112lsa w/ ESP lobes.
I will more than likley get a set of roller rockers with the new heads anyways.
Thanks!!
#1 PCR 215 $2149.99
#2 AFR 205 $2285.99
#3 ETP 215 $2399.99
#4 TFS 215 $2399.99
Thanks!!
1 Post
The TFS 215 and AFR 205 would be very similar from idle to about 4000 or 4500 rpms and then the TFS would start making more power, probably around 15 rwhp, maybe more depending on cam. In your case with a mild cam, I'd expect 10-12 rwhp. Basing my opinion on many many builds I've seen and my own 402 build. My 402 started with afr 205's and after swapping to TFS 215's gained 29.xx rwhp !!! See link in sig for back to back testing and baseline numbers. No opinion on the PRC or ETP, maybe someone else can post personal experience. Good luck.
For the money it's tough to beat the AFR's for a mild 346. Excellent street manners with great low and mid range power. The TFS are good as well and will make more power on the top end but do require the rocker wher you can run your stocker with the AFR's . I know you said you might be getting a set of rockers anyway but your talking about $500 difference in the price of the TFS with rockers vs the AFR without rockers. Just an option to look at.
I sell them ( AFR) for less than what you have listed for as well.
FYI I offer both AFR and TFS as well as WCCH Edelbrocks (which you should look at as well) as well as others.
#1 PCR 215 $2149.99
#2 AFR 205 $2285.99
#3 ETP 215 $2399.99
#4 TFS 215 $2399.99
Thanks!!
#1 PCR 215 $2149.99
#2 AFR 205 $2285.99
#3 ETP 215 $2399.99
#4 TFS 215 $2399.99
Thanks!!
Despite my porosity issues - which are now resolved.......I'd go the ETP215s again.
In saying that, however, the AFR205s work well and are direct-swap, no pushrods / valve angles to worry about.
Are they still producing the ETP215s? I thought they ceased production.
cheers,
Macca
cheers,
Macca
