LQx or rebuild the LS1? (will the LQ work with my H/C setup?)
So I finished the LS1 swap in my 240sx and its a beast but my oil pressure sucks ***** (high teens idle and 20-30's under load up to about 4k rpm) This is with a 10w-40 dino oil and a shimmed LS6/2? pump
Its my fault for not pulling the bottom end apart and mic'ing it.
So I am at a cross road, do I rebuild the LS1 (cyl were in great shape when I built it) Or do I buy an LQ4 or LQ9?
If I buy an LQx will my head Cam package work w/o PTV issues? 243's and a MS4 stock rockers/pushrod length.
Obviously if I went LQ I would go through the motor, before install.
What parts can I reuse? Since I only have maybe a 1000 miles on this build I dont want to have to get a new oil pump/pushrods/lifters/springs again.
Thanks in advance for any help.
Moderator
Everything should swap over, but I couldn't tell you about the PTV or pushrod length, that's something you'll have to figure out on your own and could be different depending on the shortblock and heads. I don't know what accessories you're using either, but you may need to drill on the front driver side of the block for a bracket.
I'd be concerned about what you did to cause the low oil pressure, so you don't do it again. Usually when it's low, it's a leak somewhere internally. Could be a pinched o-ring, or the pickup is too close to the pan.
Car runs about 190-200*
there is almost 1/4" clearance on the pan (GTO pan/pickup)
When I went to 10-40 from 5-30 it picked up ~15PSi across the board and I am using an aftermarket sensor so it rules out the stocker.
Moderator
The o-ring and pickup clearance always seem to be the most common and are usually a good place to start, however it could be bearing clearances or even the oil pump. The only way to know for sure is taking it all apart, there are a million things that could cause low oil pressure.
