what pushrods with MS3 and heads ?? hello everyone im getting a new cam setup but not sure what pushrods to use the cam is MS3>>>> Magic Stick V.3 237/242 .603/.609" lobe 114 and the heads are the PRC 2.5 62CC thank you |
What size gaskets did you get? |
im going with the stock size |
My buddy is running hardened 7.4's |
You need to measure period. Be safe not sorry |
I dont know what the base circle is on the MS3/4. Anyone know off-hand? I used to know when the magicsticks first hit the streets, that was the most common thread. Measuring is something you should always do unless it is a 224 with un-touched stock heads and 7.4 pushrods. I would like to tell you it is safe with a 62cc but I don't want to be the one that gets flogged when you have .000000002 valve float and eyelash your piston. |
Originally Posted by orangeapeel
(Post 12844438)
I dont know what the base circle is on the MS3/4. Anyone know off-hand? I used to know when the magicsticks first hit the streets, that was the most common thread. Measuring is something you should always do unless it is a 224 with un-touched stock heads and 7.4 pushrods. I would like to tell you it is safe with a 62cc but I don't want to be the one that gets flogged when you have .000000002 valve float and eyelash your piston. thank you orangeapeel for your help i guess i have to find someone to mesure it for me . |
With stock lifters and gaskets, you will more than likely need a 7.400" length pushrod. However, I would highly recommend measuring to ensure you get the right length. It's a $20 part that will save you some possible heartache down the road. Jon |
© 2024 MH Sub I, LLC dba Internet Brands
