need to know if i would have ptv clearance??? I got this setup for my ls1 a 228/232 cam with 5.3l head port and polish only....with a felpro graphite gasket from autozone,but I want to know if I would have issues with ptv clearance..I know that its a mild cam but I just want to be safe and I want to know what size is the graphite gasket thickness anyone thanks in advance!!! |
You need to measure clearance and that only you can do no matter hwo tells you what if you do not check you ptv on your own you are wrong. |
If I knew the geometry of the 5.3 head is the same as the 241s or 853s(which I don't), and I knew the lift wasn't anything stupid, as well as a relatively mild LSA, I would GUESS you would be fine. Bump it up to a 0.060 MLS gasket and use the clay method to measure IMHO |
Thanks ill try the clay method I just stick the clay to the piston and turn crank until the piston is in compression |
Ohh sorry cam 228/232 .588/.595 112 lsa |
Originally Posted by El_TransAm98
(Post 12873738)
Thanks alot |
© 2024 MH Sub I, LLC dba Internet Brands
